<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1989 switch gear wiring]]></title><description><![CDATA[<p dir="auto">I m struggling to match the wires from the switch gear to the wires in the loom  the plugs are cut off both</p>
<p dir="auto">so far I ve got this far<br />
pink . black  on switch gear go to pink  black on loom these are horn<br />
yellow .green . black on switch gear these go to headlight plug<br />
indicator plug switch has dark green brown/white brown<br />
on /off for light switch brown blue<br />
but I have these left coming from the bike loom<br />
yel/red (power fro cdi to ?)<br />
dark grren ( indicator?)<br />
blue ?</p>
]]></description><link>https://dt125r.co.uk/topic/1003/1989-switch-gear-wiring</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 02:36:08 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1003.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 Aug 2017 21:00:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1989 switch gear wiring on Tue, 05 Sep 2017 23:24:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan28" aria-label="Profile: dan28">@<bdi>dan28</bdi></a> said in <a href="/post/9831">1989 switch gear wiring</a>:</p>
<blockquote>
<p dir="auto">Thank you</p>
<p dir="auto">I m running a vapour speedo if it's wired to the blue wire does it only illuminate when the lights are on ?</p>
</blockquote>
<p dir="auto">Yes</p>
]]></description><link>https://dt125r.co.uk/post/9853</link><guid isPermaLink="true">https://dt125r.co.uk/post/9853</guid><dc:creator><![CDATA[scrimsmustang]]></dc:creator><pubDate>Tue, 05 Sep 2017 23:24:38 GMT</pubDate></item><item><title><![CDATA[Reply to 1989 switch gear wiring on Tue, 05 Sep 2017 16:52:46 GMT]]></title><description><![CDATA[<p dir="auto">Thank you</p>
<p dir="auto">I m running a vapour speedo if it's wired to the blue wire does it only illuminate when the lights are on ?<br />
Think I might wire it to brown wire so it will light up when ignition is on</p>
]]></description><link>https://dt125r.co.uk/post/9831</link><guid isPermaLink="true">https://dt125r.co.uk/post/9831</guid><dc:creator><![CDATA[dan28]]></dc:creator><pubDate>Tue, 05 Sep 2017 16:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to 1989 switch gear wiring on Tue, 05 Sep 2017 00:53:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scrimsmustang" aria-label="Profile: scrimsmustang">@<bdi>scrimsmustang</bdi></a></p>
<p dir="auto">First bit should be Light Brown from the switches to Yellow/Red from the loom.</p>
]]></description><link>https://dt125r.co.uk/post/9813</link><guid isPermaLink="true">https://dt125r.co.uk/post/9813</guid><dc:creator><![CDATA[scrimsmustang]]></dc:creator><pubDate>Tue, 05 Sep 2017 00:53:03 GMT</pubDate></item><item><title><![CDATA[Reply to 1989 switch gear wiring on Tue, 05 Sep 2017 00:23:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan28" aria-label="Profile: dan28">@<bdi>dan28</bdi></a></p>
<p dir="auto">OK Dan you should have<br />
As follows</p>
<p dir="auto">Yellow/Red from switches to Red/Yellow from loom behind the headlight, its power from the lighting coil via the regulator/rectifier.</p>
<p dir="auto">Blue from switches to the blue in the loom, its power for clock lights that come on with your lights. Goes into loom and straight back out as a double blue female connector one goes to speedo one to rev counter.</p>
<p dir="auto">Pink goes direct into pink in loom the direct to the horn.</p>
<p dir="auto">Black is a common earth and can go to any spare black coming from the main part of the loom.</p>
<p dir="auto">Dark Green is left side indicator power and indicator light in rev counter.</p>
<p dir="auto">Dark Brown same as above right side.</p>
<p dir="auto">Brown/White is power from flasher unit, goes direct to flasher unit.</p>
<p dir="auto">Yellow goes direct to headlight bulb high beam with a split connector that powers high beam light in rev counter.</p>
<p dir="auto">Green goes direct to headlight bulb normal beam</p>
]]></description><link>https://dt125r.co.uk/post/9812</link><guid isPermaLink="true">https://dt125r.co.uk/post/9812</guid><dc:creator><![CDATA[scrimsmustang]]></dc:creator><pubDate>Tue, 05 Sep 2017 00:23:52 GMT</pubDate></item></channel></rss>
