<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutch torque from Lbf ft to nm]]></title><description><![CDATA[<p dir="auto">Anyone know what the clutch nut is supposed to be set to it say 51lbf ft but my torque wrench is in nm and I've not got a clue what it's meant to be set to also how do you bend the lock plate</p>
]]></description><link>https://dt125r.co.uk/topic/1111/clutch-torque-from-lbf-ft-to-nm</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 05:15:29 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1111.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Oct 2017 02:31:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutch torque from Lbf ft to nm on Fri, 20 Oct 2017 20:08:21 GMT]]></title><description><![CDATA[<p dir="auto">I am worked on mine recently , according to the haynes manual its 7kg-m which is 68.64 nm<br />
😊</p>
]]></description><link>https://dt125r.co.uk/post/11283</link><guid isPermaLink="true">https://dt125r.co.uk/post/11283</guid><dc:creator><![CDATA[Zrako]]></dc:creator><pubDate>Fri, 20 Oct 2017 20:08:21 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch torque from Lbf ft to nm on Fri, 20 Oct 2017 06:04:54 GMT]]></title><description><![CDATA[<p dir="auto">According to Google its 69nm.</p>
<p dir="auto">As for the washer, I found that bending it slightly before fitting then using a pry bar underneath to bend it a bit more, then a chisel for the rest.</p>
]]></description><link>https://dt125r.co.uk/post/11261</link><guid isPermaLink="true">https://dt125r.co.uk/post/11261</guid><dc:creator><![CDATA[finnerz89]]></dc:creator><pubDate>Fri, 20 Oct 2017 06:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch torque from Lbf ft to nm on Fri, 20 Oct 2017 02:57:39 GMT]]></title><description><![CDATA[<p dir="auto">i believe its meant to be set to 70 nm</p>
]]></description><link>https://dt125r.co.uk/post/11260</link><guid isPermaLink="true">https://dt125r.co.uk/post/11260</guid><dc:creator><![CDATA[PerithTV]]></dc:creator><pubDate>Fri, 20 Oct 2017 02:57:39 GMT</pubDate></item></channel></rss>
