<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutch troubles......]]></title><description><![CDATA[<p dir="auto">As you will all know I’ve been doing up (or putting right l would say) a DT125.<br />
Clearly the gearbox has a oil leak as the person who had it before me had changed the cover but not the gasket, l think.<br />
Well l started the bike today and as going to take it for a little run, but as l engaged First gear, the bike stalled.<br />
Now the clutch lever still operates like before it just doesn’t disengage.<br />
Could this be that the gearbox oil is low?<br />
I’m going to sort the gasket out, should l change the clutch while I’m at it?<br />
Any advice would be kindly accepted! <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f603.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--smiley" style="height:1.4em;width:auto;vertical-align:middle" title="😃" alt="😃" /><img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--+1" style="height:1.4em;width:auto;vertical-align:middle" title="👍" alt="👍" /></p>
]]></description><link>https://dt125r.co.uk/topic/1132/clutch-troubles</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 03:27:32 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1132.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Oct 2017 20:26:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutch troubles...... on Thu, 02 Nov 2017 22:31:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> - I have had it all apart and have ordered a new kit for the impeller and seal.<br />
Whilst I’m in the clutch area l have ordered a new clutch and spring set.<br />
Fingers crossed this will solve this problem!<br />
Thanks again for your help...... to the next bodge! <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f633.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--flushed" style="height:1.4em;width:auto;vertical-align:middle" title="😳" alt="😳" /><img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--+1" style="height:1.4em;width:auto;vertical-align:middle" title="👍" alt="👍" /></p>
]]></description><link>https://dt125r.co.uk/post/11653</link><guid isPermaLink="true">https://dt125r.co.uk/post/11653</guid><dc:creator><![CDATA[Spanners]]></dc:creator><pubDate>Thu, 02 Nov 2017 22:31:00 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch troubles...... on Mon, 30 Oct 2017 22:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spanners" aria-label="Profile: spanners">@<bdi>spanners</bdi></a> It won't be the water pump gasket.</p>
<p dir="auto">It'll be the water pump seal that needs replacing bud.</p>
<p dir="auto">Should have asked here, I would have said that straight away.</p>
]]></description><link>https://dt125r.co.uk/post/11601</link><guid isPermaLink="true">https://dt125r.co.uk/post/11601</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 30 Oct 2017 22:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch troubles...... on Mon, 30 Oct 2017 22:50:17 GMT]]></title><description><![CDATA[<p dir="auto">I’m part way through my investigation, drained the gearbox oil and it looks like grey emulsion paint.<br />
So off l went on to the inter web and like seems like l have coolant in my oil.<br />
So l have ordered the gasket form behind the impela, hopefully this will sort out this particular problem.<br />
Then I’ll move onto the next bodge.... <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f633.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--flushed" style="height:1.4em;width:auto;vertical-align:middle" title="😳" alt="😳" /><img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f62a.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--sleepy" style="height:1.4em;width:auto;vertical-align:middle" title="😪" alt="😪" /></p>
]]></description><link>https://dt125r.co.uk/post/11599</link><guid isPermaLink="true">https://dt125r.co.uk/post/11599</guid><dc:creator><![CDATA[Spanners]]></dc:creator><pubDate>Mon, 30 Oct 2017 22:50:17 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch troubles...... on Sun, 29 Oct 2017 19:08:16 GMT]]></title><description><![CDATA[<p dir="auto">Yeah don't use Magnetic that stuff is no good for the cluch.</p>
<p dir="auto">Wouldn't recomend cleaning it with parafin either. Just use Castrol GTX engine oil semi-synthetic is good enough</p>
]]></description><link>https://dt125r.co.uk/post/11555</link><guid isPermaLink="true">https://dt125r.co.uk/post/11555</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 29 Oct 2017 19:08:16 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch troubles...... on Sun, 29 Oct 2017 18:54:06 GMT]]></title><description><![CDATA[<p dir="auto">I had exactly the same problem on my old DT, its because i decided to fill it up with magnatec oil which is used to hold to components so they are covered in oil before starting, however this is useless in a wet clutch bike, even with new oil they still stuck, so i removed them all, cleaned them in paraffin along with the pressure plates and spring, and then dried and coated them in new oil. i think i even changed the clutch springs because they were slightly under tolerance and only £10 or something.</p>
<p dir="auto">this worked perfectly and i only ever ran the bike on halfords special oil from then on as thats what it was happiest on.</p>
]]></description><link>https://dt125r.co.uk/post/11554</link><guid isPermaLink="true">https://dt125r.co.uk/post/11554</guid><dc:creator><![CDATA[AlfieHopkins]]></dc:creator><pubDate>Sun, 29 Oct 2017 18:54:06 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch troubles...... on Sat, 28 Oct 2017 21:07:26 GMT]]></title><description><![CDATA[<p dir="auto">Topic moved to more appropriate location.</p>
<p dir="auto">Clutches on these are pretty bullet proof.</p>
<p dir="auto">It is more than likely just a case of needing to be set up properly. But an EBC clutch kit is like £40 so it's worth replacing.</p>
<p dir="auto">But if it isn't broke don't fix it. And when it's such an easy job on these bikes why would you.</p>
<p dir="auto">I would just set the adjustment on the clutch properly and see how ytou get on.</p>
<p dir="auto">It'll either be under maximum adjustment, and not working/slipping, or you'll adjust it and it'll be fine.</p>
<p dir="auto">Usually the clutch cover gasket can be renewed, or a Kellogs Cornflake box can be utilised. But it wouldn't hurt to replace it.</p>
<p dir="auto">There could be other underlying issues.</p>
]]></description><link>https://dt125r.co.uk/post/11525</link><guid isPermaLink="true">https://dt125r.co.uk/post/11525</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 28 Oct 2017 21:07:26 GMT</pubDate></item></channel></rss>
