<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[YPVS tips]]></title><description><![CDATA[<p dir="auto">Should you lube the pv and bushes with simply 2t oil or should you grease the pv and bushes with like lithium soap? (saw it in a video)</p>
]]></description><link>https://dt125r.co.uk/topic/1136/ypvs-tips</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 18:24:07 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1136.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Nov 2017 17:47:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to YPVS tips on Mon, 15 Jan 2018 09:11:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> And as I said, if it lines up with the port then happy days.</p>
]]></description><link>https://dt125r.co.uk/post/12955</link><guid isPermaLink="true">https://dt125r.co.uk/post/12955</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 15 Jan 2018 09:11:23 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Mon, 15 Jan 2018 06:28:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> maybe i didnt express myself clearly. The pv opens and closes just as it should. My only concern is that the servo perhaps should be adjusted differently. As you can see on the picture where I have removed the servo cover, the cables are not, according to me, adjusted satisfactorily. Obviously, I have not done this before. Perhaps it's okey after all?</p>
]]></description><link>https://dt125r.co.uk/post/12954</link><guid isPermaLink="true">https://dt125r.co.uk/post/12954</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Mon, 15 Jan 2018 06:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Sun, 14 Jan 2018 21:09:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> Just whip the exhaust off and have a look. It should be flush with the exhaust port. Doesn't matter where the screws are as they should be shielded with the rubber grommets.</p>
]]></description><link>https://dt125r.co.uk/post/12951</link><guid isPermaLink="true">https://dt125r.co.uk/post/12951</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 14 Jan 2018 21:09:41 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Sun, 14 Jan 2018 21:00:03 GMT]]></title><description><![CDATA[<p dir="auto">Do you think my servo settings are okay? It works beautifully and opens right. However I am not happy with the way it is adjusted. The 2nd pulley screw is as you can see much further out than the 1st. Have a look at the servo! No pleased with that either. Woud have wanted it more centred. But frankly that was the only way it would work. Seems okey?</p>
]]></description><link>https://dt125r.co.uk/post/12950</link><guid isPermaLink="true">https://dt125r.co.uk/post/12950</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Sun, 14 Jan 2018 21:00:03 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Fri, 05 Jan 2018 18:44:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/declan" aria-label="Profile: declan">@<bdi>declan</bdi></a> naah, you guys underestimate the force required to turn that servo. Fingertips or pull HARD at the pulley</p>
]]></description><link>https://dt125r.co.uk/post/12786</link><guid isPermaLink="true">https://dt125r.co.uk/post/12786</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Fri, 05 Jan 2018 18:44:32 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Fri, 05 Jan 2018 16:03:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> yep to turn it with with your fingers would be massively overkill really</p>
]]></description><link>https://dt125r.co.uk/post/12761</link><guid isPermaLink="true">https://dt125r.co.uk/post/12761</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Fri, 05 Jan 2018 16:03:26 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Fri, 05 Jan 2018 15:50:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/declan" aria-label="Profile: declan">@<bdi>declan</bdi></a> I think turn it from the PV housing should suffice.</p>
]]></description><link>https://dt125r.co.uk/post/12760</link><guid isPermaLink="true">https://dt125r.co.uk/post/12760</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 05 Jan 2018 15:50:12 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Fri, 05 Jan 2018 15:48:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> think he might mean litteraly turning with your finger tips but the way you mentioned is the best way</p>
]]></description><link>https://dt125r.co.uk/post/12759</link><guid isPermaLink="true">https://dt125r.co.uk/post/12759</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Fri, 05 Jan 2018 15:48:29 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 04 Jan 2018 20:35:08 GMT]]></title><description><![CDATA[<p dir="auto">Yeah isn't that how you're meant to adjust them anyway. Just use a set of spanners to adjust the locking nuts, the tension ought to pull the servo the right way. Then lock off.</p>
<p dir="auto">I might be having a mental block, but that's how you adjust them.</p>
]]></description><link>https://dt125r.co.uk/post/12758</link><guid isPermaLink="true">https://dt125r.co.uk/post/12758</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 04 Jan 2018 20:35:08 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 04 Jan 2018 19:24:26 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.imgur.com/7ylGyZF.jpg" alt="0_1515093729320_20180103_161033.jpg" class="img-markdown  img-fluid" /></p>
<p dir="auto">my question is wheather or not you could "rotate" the servo manually in order to adjust the pv better.  The 2nd pulley is obviously a bit too far out.</p>
]]></description><link>https://dt125r.co.uk/post/12757</link><guid isPermaLink="true">https://dt125r.co.uk/post/12757</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Thu, 04 Jan 2018 19:24:26 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 04 Jan 2018 19:21:36 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.imgur.com/DcrVRbD.jpg" alt="0_1515093660714_20180103_161012.jpg" class="img-markdown  img-fluid" /></p>
]]></description><link>https://dt125r.co.uk/post/12756</link><guid isPermaLink="true">https://dt125r.co.uk/post/12756</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Thu, 04 Jan 2018 19:21:36 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 04 Jan 2018 14:31:39 GMT]]></title><description><![CDATA[<p dir="auto">Nope have a new one</p>
]]></description><link>https://dt125r.co.uk/post/12755</link><guid isPermaLink="true">https://dt125r.co.uk/post/12755</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Thu, 04 Jan 2018 14:31:39 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 04 Jan 2018 13:51:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> Your servo is fubar anyway right? So can't see what harm it would do.</p>
]]></description><link>https://dt125r.co.uk/post/12754</link><guid isPermaLink="true">https://dt125r.co.uk/post/12754</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 04 Jan 2018 13:51:54 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 04 Jan 2018 06:48:51 GMT]]></title><description><![CDATA[<p dir="auto">Can you twist and turn the servo motor for the pv without risking causing damage to it? I need to do so since the current setting is not optimal.</p>
]]></description><link>https://dt125r.co.uk/post/12753</link><guid isPermaLink="true">https://dt125r.co.uk/post/12753</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Thu, 04 Jan 2018 06:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Sun, 24 Dec 2017 10:11:04 GMT]]></title><description><![CDATA[<p dir="auto">Yup, it seems you can fit it upside down, thus restricking the bike.<br />
Im pretty sure some bikes where sold in a restricted version like this.</p>
]]></description><link>https://dt125r.co.uk/post/12471</link><guid isPermaLink="true">https://dt125r.co.uk/post/12471</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Sun, 24 Dec 2017 10:11:04 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Sat, 23 Dec 2017 16:21:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> It means ensuring it's not upside down....I'd imagine.</p>
]]></description><link>https://dt125r.co.uk/post/12462</link><guid isPermaLink="true">https://dt125r.co.uk/post/12462</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 23 Dec 2017 16:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Sat, 23 Dec 2017 14:39:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> I guess it’s in the manual for a reason but I don’t actually know</p>
]]></description><link>https://dt125r.co.uk/post/12461</link><guid isPermaLink="true">https://dt125r.co.uk/post/12461</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Sat, 23 Dec 2017 14:39:05 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Sat, 23 Dec 2017 14:33:44 GMT]]></title><description><![CDATA[<p dir="auto">The Haynes manual says you need to make sure the pv is mounted correctly and not 180° wrong. Is it possible to mount it wrong? I mean it only fits one way?</p>
]]></description><link>https://dt125r.co.uk/post/12460</link><guid isPermaLink="true">https://dt125r.co.uk/post/12460</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Sat, 23 Dec 2017 14:33:44 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 02 Nov 2017 11:34:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zrako" aria-label="Profile: zrako">@<bdi>zrako</bdi></a> when I rebuilt my top end my o rings were no bullshit litteraly square although my piston was about 2 years of hard riding old</p>
]]></description><link>https://dt125r.co.uk/post/11641</link><guid isPermaLink="true">https://dt125r.co.uk/post/11641</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Thu, 02 Nov 2017 11:34:11 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 02 Nov 2017 11:17:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> when Im cleaned mine , I had new seal and old seal in hand and couldnt tell the difference.</p>
]]></description><link>https://dt125r.co.uk/post/11640</link><guid isPermaLink="true">https://dt125r.co.uk/post/11640</guid><dc:creator><![CDATA[Zrako]]></dc:creator><pubDate>Thu, 02 Nov 2017 11:17:08 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 02 Nov 2017 08:46:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> Pretty sure it comes with the Athena gasket kit.</p>
<p dir="auto">I can't say I have ever gone out my way to replace the o ring or clean the valve.</p>
]]></description><link>https://dt125r.co.uk/post/11639</link><guid isPermaLink="true">https://dt125r.co.uk/post/11639</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 02 Nov 2017 08:46:02 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Thu, 02 Nov 2017 05:58:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glynn123" aria-label="Profile: glynn123">@<bdi>glynn123</bdi></a> when cleaning the pv. Should you always buy new o rings or can they normally be reused? How many km until you should inspect and clean?</p>
]]></description><link>https://dt125r.co.uk/post/11638</link><guid isPermaLink="true">https://dt125r.co.uk/post/11638</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Thu, 02 Nov 2017 05:58:11 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Wed, 01 Nov 2017 19:25:51 GMT]]></title><description><![CDATA[<p dir="auto">Didnt bother lubing my PV after rebuilding, ensured all surfaces were very clean and mirror polished, it doesnt do a full rotation and moves as much as say a rev counter or speedometer, the bushes would well outlast a piston un lubed, the thing you should really worry about it carbon sticking to the powervalve, so keep it clean and if you can be arsed mirror polish it.</p>
]]></description><link>https://dt125r.co.uk/post/11636</link><guid isPermaLink="true">https://dt125r.co.uk/post/11636</guid><dc:creator><![CDATA[Glynn123]]></dc:creator><pubDate>Wed, 01 Nov 2017 19:25:51 GMT</pubDate></item><item><title><![CDATA[Reply to YPVS tips on Wed, 01 Nov 2017 18:37:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> I used 2 stroke on mine so do as I did as I think the grease is highly not needed and I personally would not trust the grease as I’ve heated grease up general purpose ad it gets quite waxy and may even combust</p>
]]></description><link>https://dt125r.co.uk/post/11634</link><guid isPermaLink="true">https://dt125r.co.uk/post/11634</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Wed, 01 Nov 2017 18:37:43 GMT</pubDate></item></channel></rss>
