<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DT125RE Cutting out when put in to gear.]]></title><description><![CDATA[<p dir="auto">Hi All!</p>
<p dir="auto">I'm having a bit of an issue with my DT125RE 2005..<br />
I've recently just had the head and cylinder skimmed and have just put everything back together.</p>
<p dir="auto">Bike starts fine, but the second I put the bike in to gear with the clutch in, it completely cuts out. This is in first and second, bike will also not bump in gear.</p>
<p dir="auto">The previous owner has deactivated the bike stand switch and this has never been a problem whilst I've had the bike.</p>
<p dir="auto">I've been reading elsewhere that this could be a clutch switch issue..</p>
<p dir="auto">Has anybody else had this problem? If so, do you have any tips for tackling the issue?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://dt125r.co.uk/topic/1141/dt125re-cutting-out-when-put-in-to-gear</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 03:22:06 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1141.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Nov 2017 14:13:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DT125RE Cutting out when put in to gear. on Sun, 05 Nov 2017 17:02:06 GMT]]></title><description><![CDATA[<p dir="auto">I'll take another look at the side stand switch tomorrow and let you know, its not been on for the past 5 months as far as I'm aware.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zrako" aria-label="Profile: Zrako">@<bdi>Zrako</bdi></a> The bike doesn't pull when it goes in to gear at all.</p>
]]></description><link>https://dt125r.co.uk/post/11691</link><guid isPermaLink="true">https://dt125r.co.uk/post/11691</guid><dc:creator><![CDATA[PJT95]]></dc:creator><pubDate>Sun, 05 Nov 2017 17:02:06 GMT</pubDate></item><item><title><![CDATA[Reply to DT125RE Cutting out when put in to gear. on Sun, 05 Nov 2017 16:55:52 GMT]]></title><description><![CDATA[<p dir="auto">It'll be the side switch stand.</p>
<p dir="auto">There should be no reason why it needs to be bypassed. I would put it back in the loop, either get a new one, or used off eBay.</p>
<p dir="auto">Pretty sure all the clutch switch is used for is to cut the engine should the side stand switch be closed.</p>
<p dir="auto">So it'll be the side stand switch.</p>
]]></description><link>https://dt125r.co.uk/post/11690</link><guid isPermaLink="true">https://dt125r.co.uk/post/11690</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 05 Nov 2017 16:55:52 GMT</pubDate></item><item><title><![CDATA[Reply to DT125RE Cutting out when put in to gear. on Sun, 05 Nov 2017 16:53:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pjt95" aria-label="Profile: pjt95">@<bdi>pjt95</bdi></a> do you feel when you put it in the gear the bike moves a bit ?</p>
]]></description><link>https://dt125r.co.uk/post/11689</link><guid isPermaLink="true">https://dt125r.co.uk/post/11689</guid><dc:creator><![CDATA[Zrako]]></dc:creator><pubDate>Sun, 05 Nov 2017 16:53:16 GMT</pubDate></item><item><title><![CDATA[Reply to DT125RE Cutting out when put in to gear. on Sun, 05 Nov 2017 16:01:40 GMT]]></title><description><![CDATA[<p dir="auto">You can bridge out the side stand relay to see if that or something else in the circuit is faulty.</p>
]]></description><link>https://dt125r.co.uk/post/11687</link><guid isPermaLink="true">https://dt125r.co.uk/post/11687</guid><dc:creator><![CDATA[DTR+NSR]]></dc:creator><pubDate>Sun, 05 Nov 2017 16:01:40 GMT</pubDate></item></channel></rss>
