<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutch spring bolt size??]]></title><description><![CDATA[<p dir="auto">Hi all, like a total idiot I've over tightened a clutch spring bolt. Just need to know the thread size of the bolts as I've seen a few different sizes/lengths when looking for some new ones?? I've seen m5 and m6 at different lengths so not 100% sure.<br />
Thanks in advance.</p>
]]></description><link>https://dt125r.co.uk/topic/1173/clutch-spring-bolt-size</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 05:18:21 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1173.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Nov 2017 15:42:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 19:36:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitch_350z" aria-label="Profile: mitch_350z">@<bdi>mitch_350z</bdi></a> Right, yeah 10mm IIRC. I replaced all mine with M6 Stainless Steel Hex heads.</p>
]]></description><link>https://dt125r.co.uk/post/12040</link><guid isPermaLink="true">https://dt125r.co.uk/post/12040</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 22 Nov 2017 19:36:29 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 19:34:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> I meant the head of the bolt for the clutch bolt springs</p>
]]></description><link>https://dt125r.co.uk/post/12039</link><guid isPermaLink="true">https://dt125r.co.uk/post/12039</guid><dc:creator><![CDATA[Mitch_350z]]></dc:creator><pubDate>Wed, 22 Nov 2017 19:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 19:32:02 GMT]]></title><description><![CDATA[<p dir="auto">Head bolts?<br />
Or nuts. Since you shouldn't be using bolts on the head.</p>
<p dir="auto">M10 Head Nuts  IIRC.</p>
]]></description><link>https://dt125r.co.uk/post/12038</link><guid isPermaLink="true">https://dt125r.co.uk/post/12038</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 22 Nov 2017 19:32:02 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 18:32:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ricky0115" aria-label="Profile: ricky0115">@<bdi>ricky0115</bdi></a> do you mean 3/8”?</p>
]]></description><link>https://dt125r.co.uk/post/12037</link><guid isPermaLink="true">https://dt125r.co.uk/post/12037</guid><dc:creator><![CDATA[finnerz89]]></dc:creator><pubDate>Wed, 22 Nov 2017 18:32:54 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 16:27:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ricky0115" aria-label="Profile: ricky0115">@<bdi>ricky0115</bdi></a> alright, thanks for the info</p>
]]></description><link>https://dt125r.co.uk/post/12035</link><guid isPermaLink="true">https://dt125r.co.uk/post/12035</guid><dc:creator><![CDATA[Mitch_350z]]></dc:creator><pubDate>Wed, 22 Nov 2017 16:27:10 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 16:17:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitch_350z" aria-label="Profile: mitch_350z">@<bdi>mitch_350z</bdi></a> 10mm or 1/4”</p>
]]></description><link>https://dt125r.co.uk/post/12034</link><guid isPermaLink="true">https://dt125r.co.uk/post/12034</guid><dc:creator><![CDATA[ricky0115]]></dc:creator><pubDate>Wed, 22 Nov 2017 16:17:55 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 16:13:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ricky0115" aria-label="Profile: ricky0115">@<bdi>ricky0115</bdi></a> alright mate thanks, do you know what size head the bolts are as I haven't got them to hand and can't remember of the top of my head</p>
]]></description><link>https://dt125r.co.uk/post/12033</link><guid isPermaLink="true">https://dt125r.co.uk/post/12033</guid><dc:creator><![CDATA[Mitch_350z]]></dc:creator><pubDate>Wed, 22 Nov 2017 16:13:53 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 16:05:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitch_350z" aria-label="Profile: mitch_350z">@<bdi>mitch_350z</bdi></a> I know it’s the same as 04 DTRE</p>
]]></description><link>https://dt125r.co.uk/post/12032</link><guid isPermaLink="true">https://dt125r.co.uk/post/12032</guid><dc:creator><![CDATA[ricky0115]]></dc:creator><pubDate>Wed, 22 Nov 2017 16:05:22 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 16:03:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ricky0115" aria-label="Profile: ricky0115">@<bdi>ricky0115</bdi></a> would that be the same as a 2002 model??</p>
]]></description><link>https://dt125r.co.uk/post/12031</link><guid isPermaLink="true">https://dt125r.co.uk/post/12031</guid><dc:creator><![CDATA[Mitch_350z]]></dc:creator><pubDate>Wed, 22 Nov 2017 16:03:42 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch spring bolt size?? on Wed, 22 Nov 2017 15:58:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitch_350z" aria-label="Profile: mitch_350z">@<bdi>mitch_350z</bdi></a>  my 98 DTR is M6 x 20mm</p>
]]></description><link>https://dt125r.co.uk/post/12030</link><guid isPermaLink="true">https://dt125r.co.uk/post/12030</guid><dc:creator><![CDATA[ricky0115]]></dc:creator><pubDate>Wed, 22 Nov 2017 15:58:55 GMT</pubDate></item></channel></rss>
