<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powervalve  dtr 2002]]></title><description><![CDATA[<p dir="auto">My powervalve doesn’t seem to work properly I recent replace the the servo put new one on I think got the cables on right when put the battery on it turns one way doesn’t return has now bottom power I’ve set the it up with the cables so it lines up with the hole if u put battery on it goes clockwise and stays there can hear the servo trying to move but won’t moves freely with hand any help much apriciated thanks</p>
]]></description><link>https://dt125r.co.uk/topic/1179/powervalve-dtr-2002</link><generator>RSS for Node</generator><lastBuildDate>Thu, 19 Nov 2026 05:41:17 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1179.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Nov 2017 23:42:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sun, 03 Dec 2017 09:46:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cartermarc1" aria-label="Profile: cartermarc1">@<bdi>cartermarc1</bdi></a> The valve will be flush with the exhaust port, since the valves job is to altr the exhaust port height to enable better low end performance by restricting lost fuel and air theough the open port.</p>
]]></description><link>https://dt125r.co.uk/post/12196</link><guid isPermaLink="true">https://dt125r.co.uk/post/12196</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 03 Dec 2017 09:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sun, 03 Dec 2017 09:30:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> to set it to open is powervalve is flush with the top ? Thanks for all your help</p>
]]></description><link>https://dt125r.co.uk/post/12195</link><guid isPermaLink="true">https://dt125r.co.uk/post/12195</guid><dc:creator><![CDATA[cartermarc1]]></dc:creator><pubDate>Sun, 03 Dec 2017 09:30:43 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sat, 02 Dec 2017 19:03:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cartermarc1" aria-label="Profile: cartermarc1">@<bdi>cartermarc1</bdi></a> Set it to open and lock off the nut to stop it rotating.</p>
]]></description><link>https://dt125r.co.uk/post/12177</link><guid isPermaLink="true">https://dt125r.co.uk/post/12177</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 02 Dec 2017 19:03:53 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sat, 02 Dec 2017 18:58:18 GMT]]></title><description><![CDATA[<p dir="auto">How do I pin the valve thanks</p>
]]></description><link>https://dt125r.co.uk/post/12176</link><guid isPermaLink="true">https://dt125r.co.uk/post/12176</guid><dc:creator><![CDATA[cartermarc1]]></dc:creator><pubDate>Sat, 02 Dec 2017 18:58:18 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sat, 02 Dec 2017 18:45:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cartermarc1" aria-label="Profile: cartermarc1">@<bdi>cartermarc1</bdi></a> I don't suspect it's the servo.</p>
<p dir="auto">When I had this issue, it was the CDI that was faulty (since the servo's operation is controlled by the CDI). But depending on your model it might be a separate ECU.</p>
<p dir="auto">For a 2002, I believe it's the CDI.</p>
<p dir="auto">I would just leave it disconnected, and pin the valve open for now.</p>
]]></description><link>https://dt125r.co.uk/post/12175</link><guid isPermaLink="true">https://dt125r.co.uk/post/12175</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 02 Dec 2017 18:45:13 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sat, 02 Dec 2017 18:38:32 GMT]]></title><description><![CDATA[<p dir="auto">No mate its not only turning one way have a look for a new servo how do I open it fully while I find one  thanks for the help</p>
]]></description><link>https://dt125r.co.uk/post/12174</link><guid isPermaLink="true">https://dt125r.co.uk/post/12174</guid><dc:creator><![CDATA[cartermarc1]]></dc:creator><pubDate>Sat, 02 Dec 2017 18:38:32 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sat, 02 Dec 2017 15:25:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cartermarc1" aria-label="Profile: cartermarc1">@<bdi>cartermarc1</bdi></a> It doesn't do a cleaning cycle then? Only going one way and not returning.</p>
<p dir="auto">Sounds like the servo ECU is burnt out.</p>
]]></description><link>https://dt125r.co.uk/post/12171</link><guid isPermaLink="true">https://dt125r.co.uk/post/12171</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 02 Dec 2017 15:25:47 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Sat, 02 Dec 2017 13:56:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> I’ve took the cables off it’s working anti-clockwise on the servo but only when I turn it clockwise with my hand</p>
]]></description><link>https://dt125r.co.uk/post/12170</link><guid isPermaLink="true">https://dt125r.co.uk/post/12170</guid><dc:creator><![CDATA[cartermarc1]]></dc:creator><pubDate>Sat, 02 Dec 2017 13:56:36 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Wed, 29 Nov 2017 17:22:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cartermarc1" aria-label="Profile: cartermarc1">@<bdi>cartermarc1</bdi></a> I would disconnect the cables and just make sure the valve does a sweep properly when you switch the ignition on and off.</p>
]]></description><link>https://dt125r.co.uk/post/12145</link><guid isPermaLink="true">https://dt125r.co.uk/post/12145</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 29 Nov 2017 17:22:45 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Wed, 29 Nov 2017 17:15:10 GMT]]></title><description><![CDATA[<p dir="auto">)I was wondering if I had the cables the Wright way round I’ve read that some are crossed over</p>
]]></description><link>https://dt125r.co.uk/post/12144</link><guid isPermaLink="true">https://dt125r.co.uk/post/12144</guid><dc:creator><![CDATA[cartermarc1]]></dc:creator><pubDate>Wed, 29 Nov 2017 17:15:10 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Tue, 28 Nov 2017 19:41:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> ok mate thanks</p>
]]></description><link>https://dt125r.co.uk/post/12132</link><guid isPermaLink="true">https://dt125r.co.uk/post/12132</guid><dc:creator><![CDATA[cartermarc1]]></dc:creator><pubDate>Tue, 28 Nov 2017 19:41:07 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Tue, 28 Nov 2017 08:24:30 GMT]]></title><description><![CDATA[<p dir="auto">I had a similar problem when my cdi went faulty. Was an aftermarket CDI mind you.</p>
]]></description><link>https://dt125r.co.uk/post/12126</link><guid isPermaLink="true">https://dt125r.co.uk/post/12126</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 28 Nov 2017 08:24:30 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Tue, 28 Nov 2017 06:42:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/declan" aria-label="Profile: declan">@<bdi>declan</bdi></a> Ile take a picture of them won’t be Wednesday night tho there not tight got no.1 going to no.1 same with no.2 from pics I’ve seen of others looks right thanks</p>
]]></description><link>https://dt125r.co.uk/post/12125</link><guid isPermaLink="true">https://dt125r.co.uk/post/12125</guid><dc:creator><![CDATA[cartermarc1]]></dc:creator><pubDate>Tue, 28 Nov 2017 06:42:00 GMT</pubDate></item><item><title><![CDATA[Reply to Powervalve  dtr 2002 on Tue, 28 Nov 2017 03:11:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cartermarc1" aria-label="Profile: cartermarc1">@<bdi>cartermarc1</bdi></a> sure your cables aren’t too tight?</p>
]]></description><link>https://dt125r.co.uk/post/12124</link><guid isPermaLink="true">https://dt125r.co.uk/post/12124</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Tue, 28 Nov 2017 03:11:13 GMT</pubDate></item></channel></rss>
