<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Snorkel out flat power curve?]]></title><description><![CDATA[<p dir="auto">First ride today in a long time also the first ever without snorkel it seems to rev higher without snorkel but the power seems quite flat is this due to the snorkel I know it’s not got the designed air flow or is it just me thinking there’s less power I have been riding another bike but that had less power so it’s not like I’m used to riding a bigger bike either way snorkel is going back in just curious if the snorkel out affects the power this bad</p>
]]></description><link>https://dt125r.co.uk/topic/1192/snorkel-out-flat-power-curve</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 04:21:48 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1192.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Dec 2017 00:27:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Snorkel out flat power curve? on Fri, 08 Dec 2017 14:11:54 GMT]]></title><description><![CDATA[<p dir="auto">Removing the snorkel affects the jetting, so jet accordingly. It can also decrese the low end a bit, as theres not much velocity through the carb when you whack the throttle open at low speed.<br />
IMO the airbox seems pretty restrictive, so removing the snorkel adds tons of air.</p>
<p dir="auto">You can be both rich and lean, as in lean in the midrange, and rich on the mainjet, or the other way around.</p>
]]></description><link>https://dt125r.co.uk/post/12284</link><guid isPermaLink="true">https://dt125r.co.uk/post/12284</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Fri, 08 Dec 2017 14:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to Snorkel out flat power curve? on Fri, 08 Dec 2017 11:39:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jens-eskildsen" aria-label="Profile: jens-eskildsen">@<bdi>jens-eskildsen</bdi></a> nah my jetting is spot on if anything slightly rich I guess it don’t suit my bike it’s going back in before my next ride anyways</p>
]]></description><link>https://dt125r.co.uk/post/12282</link><guid isPermaLink="true">https://dt125r.co.uk/post/12282</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Fri, 08 Dec 2017 11:39:03 GMT</pubDate></item><item><title><![CDATA[Reply to Snorkel out flat power curve? on Fri, 08 Dec 2017 09:31:17 GMT]]></title><description><![CDATA[<p dir="auto">You need to jet for it, you cant just unbolt it and expect to unleash lots of power.<br />
Youre probably a bit lean, hence the "flat" feeling.</p>
]]></description><link>https://dt125r.co.uk/post/12276</link><guid isPermaLink="true">https://dt125r.co.uk/post/12276</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Fri, 08 Dec 2017 09:31:17 GMT</pubDate></item></channel></rss>
