<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutch slip ?]]></title><description><![CDATA[<p dir="auto">Would having low engine oil due to oil leak cause the clutch to slip since it uses the oil for friction? And can clutch slip occur when your setting off meaning you need lots of revs to start moving</p>
]]></description><link>https://dt125r.co.uk/topic/1231/clutch-slip</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 17:21:17 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1231.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Dec 2017 21:28:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 17:48:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> okidoki</p>
]]></description><link>https://dt125r.co.uk/post/12710</link><guid isPermaLink="true">https://dt125r.co.uk/post/12710</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Mon, 01 Jan 2018 17:48:34 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 16:55:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jens-eskildsen" aria-label="Profile: jens-eskildsen">@<bdi>jens-eskildsen</bdi></a> Lol, I sort of implied that in my first post. Kinda thought he might have got that. But yes, the point I was trying to make, low oil won't make it slip, as more powerful engines use dry clutches.</p>
]]></description><link>https://dt125r.co.uk/post/12709</link><guid isPermaLink="true">https://dt125r.co.uk/post/12709</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 01 Jan 2018 16:55:04 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 16:32:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jens-eskildsen" aria-label="Profile: jens-eskildsen">@<bdi>jens-eskildsen</bdi></a> okay thanks</p>
]]></description><link>https://dt125r.co.uk/post/12708</link><guid isPermaLink="true">https://dt125r.co.uk/post/12708</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Mon, 01 Jan 2018 16:32:23 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 15:55:01 GMT]]></title><description><![CDATA[<p dir="auto">Low on oil wont make the clutch slip.</p>
]]></description><link>https://dt125r.co.uk/post/12706</link><guid isPermaLink="true">https://dt125r.co.uk/post/12706</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Mon, 01 Jan 2018 15:55:01 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 15:13:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/declan" aria-label="Profile: declan">@<bdi>declan</bdi></a> It's a wet clutch system, so it needs to be lubed up prior to installing. But put oil on a dry clutch system and see how you get on.</p>
<p dir="auto">There are only a handful of high powered wet clutch setups, the rest are all dry clutch.</p>
]]></description><link>https://dt125r.co.uk/post/12705</link><guid isPermaLink="true">https://dt125r.co.uk/post/12705</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 01 Jan 2018 15:13:56 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 13:20:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> well if the last thing you want on there is oil why is the first thing you put on there oil I could of sworn they got covered in oil but I guess I was wrong</p>
]]></description><link>https://dt125r.co.uk/post/12697</link><guid isPermaLink="true">https://dt125r.co.uk/post/12697</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Mon, 01 Jan 2018 13:20:45 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 08:54:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/declan" aria-label="Profile: declan">@<bdi>declan</bdi></a> Yeah, so?</p>
]]></description><link>https://dt125r.co.uk/post/12690</link><guid isPermaLink="true">https://dt125r.co.uk/post/12690</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 01 Jan 2018 08:54:48 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Mon, 01 Jan 2018 02:15:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> but you soak clutch plates in oil?</p>
]]></description><link>https://dt125r.co.uk/post/12689</link><guid isPermaLink="true">https://dt125r.co.uk/post/12689</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Mon, 01 Jan 2018 02:15:46 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch slip ? on Sun, 31 Dec 2017 22:06:20 GMT]]></title><description><![CDATA[<p dir="auto">Oil is the last thing you want on clutch plates, else they slip. The DT just so happens to mix the gearbox oil into the clutch housing. That's fine so long as everything is torqued to spec. But as a general rule of thumb, no oil is not what you want on clutch plates.</p>
<p dir="auto">Also add, you don't really want to be giving a slipping clutch revs, since this will just cause it to wear out.</p>
]]></description><link>https://dt125r.co.uk/post/12679</link><guid isPermaLink="true">https://dt125r.co.uk/post/12679</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 31 Dec 2017 22:06:20 GMT</pubDate></item></channel></rss>
