<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Right crank seal]]></title><description><![CDATA[<p dir="auto">Which way round should the right crank seal be fitted? Haynes mentions the seal is marked 'outside' which should face towards the primary drive. But this being a patern seal from pjme isn't marked that way.</p>
<p dir="auto"><img src="https://i.imgur.com/S67NDuE.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/ElEHDaM.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/topic/1250/right-crank-seal</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 23:11:35 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1250.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Jan 2018 19:32:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Right crank seal on Wed, 17 Jan 2018 09:24:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dtr-nsr" aria-label="Profile: dtr-nsr">@<bdi>dtr-nsr</bdi></a> That's really odd.</p>
<p dir="auto">As said then, I guess it is just reversible.</p>
]]></description><link>https://dt125r.co.uk/post/12971</link><guid isPermaLink="true">https://dt125r.co.uk/post/12971</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 17 Jan 2018 09:24:16 GMT</pubDate></item><item><title><![CDATA[Reply to Right crank seal on Wed, 17 Jan 2018 07:40:20 GMT]]></title><description><![CDATA[<p dir="auto">There's a spring/metal ring both sides of the seal.</p>
]]></description><link>https://dt125r.co.uk/post/12969</link><guid isPermaLink="true">https://dt125r.co.uk/post/12969</guid><dc:creator><![CDATA[DTR+NSR]]></dc:creator><pubDate>Wed, 17 Jan 2018 07:40:20 GMT</pubDate></item><item><title><![CDATA[Reply to Right crank seal on Tue, 16 Jan 2018 22:16:21 GMT]]></title><description><![CDATA[<p dir="auto">Oh right. Yeah mate. That metal ring faces the crank shaft.</p>
<p dir="auto">So you shouldn't see that from the clutch side.</p>
]]></description><link>https://dt125r.co.uk/post/12968</link><guid isPermaLink="true">https://dt125r.co.uk/post/12968</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 16 Jan 2018 22:16:21 GMT</pubDate></item><item><title><![CDATA[Reply to Right crank seal on Tue, 16 Jan 2018 20:32:08 GMT]]></title><description><![CDATA[<p dir="auto">Its probably impossible to tell from the pics but there is a slight difference between the lips of the seal.</p>
<p dir="auto"><img src="https://i.imgur.com/1tenfyM.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Didn't know if anyone had a rebuild pic showing the standard seal in position I could compare mine to :confused_face:</p>
]]></description><link>https://dt125r.co.uk/post/12967</link><guid isPermaLink="true">https://dt125r.co.uk/post/12967</guid><dc:creator><![CDATA[DTR+NSR]]></dc:creator><pubDate>Tue, 16 Jan 2018 20:32:08 GMT</pubDate></item><item><title><![CDATA[Reply to Right crank seal on Tue, 16 Jan 2018 19:54:44 GMT]]></title><description><![CDATA[<p dir="auto">They look reversible to me bud.</p>
<p dir="auto">Usually it's the part with the writing on that should face the clutch. I.e. you should be able to see it from the clutch side.</p>
<p dir="auto">But seeing as there is writing on both sides, and the seal looks identical, I guess it's reversible. This is unusual since the genuine ones are not.</p>
]]></description><link>https://dt125r.co.uk/post/12964</link><guid isPermaLink="true">https://dt125r.co.uk/post/12964</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 16 Jan 2018 19:54:44 GMT</pubDate></item></channel></rss>
