<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[First dt]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://dt125r.co.uk/topic/126/first-dt</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 17:30:47 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/126.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Mar 2016 14:29:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to First dt on Thu, 14 Apr 2016 22:57:50 GMT]]></title><description><![CDATA[<p dir="auto">Just an update <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:1.4em;width:auto;vertical-align:middle" title=":)" alt="🙂" /> come start of the month she is getting new clutch as that's forever needing slipping, new top end, new brakes and a tail tidy!! Except for top end I'm attempting the rest meself <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f631.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--scream" style="height:1.4em;width:auto;vertical-align:middle" title="😱" alt="😱" /></p>
]]></description><link>https://dt125r.co.uk/post/1258</link><guid isPermaLink="true">https://dt125r.co.uk/post/1258</guid><dc:creator><![CDATA[DevonDtr]]></dc:creator><pubDate>Thu, 14 Apr 2016 22:57:50 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Sat, 12 Mar 2016 13:39:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/devondtr" aria-label="Profile: DevonDtr">@<bdi>DevonDtr</bdi></a> engine will sound rough. Sound like there is sand in the engine.</p>
]]></description><link>https://dt125r.co.uk/post/798</link><guid isPermaLink="true">https://dt125r.co.uk/post/798</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 12 Mar 2016 13:39:01 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Sat, 12 Mar 2016 13:37:17 GMT]]></title><description><![CDATA[<p dir="auto">To be fair I have learnt loads engine wise since I have had it, hopefully I can make it mint. Is there anything I should look for that would lead up to engine failure?</p>
]]></description><link>https://dt125r.co.uk/post/797</link><guid isPermaLink="true">https://dt125r.co.uk/post/797</guid><dc:creator><![CDATA[DevonDtr]]></dc:creator><pubDate>Sat, 12 Mar 2016 13:37:17 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Sat, 12 Mar 2016 10:14:35 GMT]]></title><description><![CDATA[<p dir="auto">Yeah fair enough.</p>
<p dir="auto">Don't dispair if the engine does fail though.</p>
<p dir="auto">They are so easy to rebuild you do not need many special tools to rebuild.</p>
]]></description><link>https://dt125r.co.uk/post/794</link><guid isPermaLink="true">https://dt125r.co.uk/post/794</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 12 Mar 2016 10:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Sat, 12 Mar 2016 08:18:33 GMT]]></title><description><![CDATA[<p dir="auto">It was more a case of checking compression, and replacing things. This thing was missing so many bolts and gaskets etc</p>
]]></description><link>https://dt125r.co.uk/post/793</link><guid isPermaLink="true">https://dt125r.co.uk/post/793</guid><dc:creator><![CDATA[DevonDtr]]></dc:creator><pubDate>Sat, 12 Mar 2016 08:18:33 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Fri, 11 Mar 2016 23:32:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/devondtr" aria-label="Profile: DevonDtr">@<bdi>DevonDtr</bdi></a> mine got nicked at the gym. So lesson learned always lock it up.</p>
<p dir="auto">I wouldn't be told. It took for it to get nicked before I locked it up.</p>
<p dir="auto">There's not a lot a garage can really do. Compression test and dismantle the barrel for wear. But then it's like if you're going to take it apart you may as well replace the parts.</p>
<p dir="auto">Should be alright. Those engines are going to be pretty bomb proof.</p>
]]></description><link>https://dt125r.co.uk/post/790</link><guid isPermaLink="true">https://dt125r.co.uk/post/790</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 11 Mar 2016 23:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Fri, 11 Mar 2016 23:13:35 GMT]]></title><description><![CDATA[<p dir="auto">Shame it got nicked though. Luckily mines kept in a secure place! Hopefully after a few more mods and tidy up it will look ace. Forgot to say in previous post that garage checked engine over and its all decent insidr <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:1.4em;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://dt125r.co.uk/post/789</link><guid isPermaLink="true">https://dt125r.co.uk/post/789</guid><dc:creator><![CDATA[DevonDtr]]></dc:creator><pubDate>Fri, 11 Mar 2016 23:13:35 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Fri, 11 Mar 2016 21:07:12 GMT]]></title><description><![CDATA[<p dir="auto">Oh good lad. It can be hard to get it pucker when using it daily.</p>
<p dir="auto">Mine was mint. Got nicked 12 months later. Spent 2 years in a battered state and I am.finally restoring it.</p>
<p dir="auto">I liked the battered bike as it just meant I could use it and not worry about its asthetics. Embarrassing to be seen on mine was. But it was still a solid ride.</p>
]]></description><link>https://dt125r.co.uk/post/783</link><guid isPermaLink="true">https://dt125r.co.uk/post/783</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 11 Mar 2016 21:07:12 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Fri, 11 Mar 2016 19:08:48 GMT]]></title><description><![CDATA[<p dir="auto">That pic was from when I first got it, so far she's had all new chain and sprockets, fresh paint,  exhaust, new grips etc hoping to paint it back to blue next month</p>
]]></description><link>https://dt125r.co.uk/post/780</link><guid isPermaLink="true">https://dt125r.co.uk/post/780</guid><dc:creator><![CDATA[DevonDtr]]></dc:creator><pubDate>Fri, 11 Mar 2016 19:08:48 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Fri, 11 Mar 2016 15:34:34 GMT]]></title><description><![CDATA[<p dir="auto">Doesn't look to be in the healthiest of condition, but nothin broke can't be fixed!</p>
]]></description><link>https://dt125r.co.uk/post/776</link><guid isPermaLink="true">https://dt125r.co.uk/post/776</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 11 Mar 2016 15:34:34 GMT</pubDate></item><item><title><![CDATA[Reply to First dt on Fri, 11 Mar 2016 15:33:52 GMT]]></title><description><![CDATA[<p dir="auto">Not sure what you tried posting there...</p>
<p dir="auto"><img src="https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xpt1/v/t1.0-9/fr/cp0/e15/q65/12687840_10153809797471421_2502968191711027314_n.jpg?efg=eyJpIjoidCJ9&amp;oh=7db1e1355436397393de7df732bc7da4&amp;oe=57514540" alt="alt" class="img-markdown  img-fluid" /></p>
]]></description><link>https://dt125r.co.uk/post/775</link><guid isPermaLink="true">https://dt125r.co.uk/post/775</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 11 Mar 2016 15:33:52 GMT</pubDate></item></channel></rss>
