<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[320mm discs that fit DTX Front hub?]]></title><description><![CDATA[<p dir="auto">Hi, I've recently got a set of DTX hubs laced to saxess supermoto rims, as I've fitted wr 426 forks onto my DT I will have to make a custom adapter to use the stock DTX front disc, however I can buy an adapter to run a 320mm disc...<br />
I measured my DTX disc at 300mm, sadly not enough for the adapter to work</p>
<p dir="auto">I wonder if there's any other bikes out there running the same stud spacing and pattern? Possibly Aprillias?</p>
]]></description><link>https://dt125r.co.uk/topic/1308/320mm-discs-that-fit-dtx-front-hub</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 22:07:48 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1308.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Feb 2018 22:34:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 320mm discs that fit DTX Front hub? on Fri, 16 Feb 2018 23:17:28 GMT]]></title><description><![CDATA[<p dir="auto">Doubtful, but an adapter shouldn't be too hard to make. Just make sure you centralise the caliper over the disc.</p>
]]></description><link>https://dt125r.co.uk/post/13481</link><guid isPermaLink="true">https://dt125r.co.uk/post/13481</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 16 Feb 2018 23:17:28 GMT</pubDate></item></channel></rss>
