<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cutout acceptable?]]></title><description><![CDATA[<p dir="auto">As you can see the entire top of the airbox has been cutout (not by me). The question is weather its safe enought from scrap, dirt and water? I dont mind cleaning it often. Or should I do something about it? It will be rejetted since I have installed a few bits and pieces during the winter.</p>
<p dir="auto"><img src="https://i.imgur.com/NjkNL3d.jpg" alt="0_1519284990879_20180217_135409.jpg" class="img-markdown  img-fluid" /></p>
]]></description><link>https://dt125r.co.uk/topic/1316/cutout-acceptable</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 00:45:26 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1316.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Feb 2018 07:40:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cutout acceptable? on Wed, 02 May 2018 14:44:28 GMT]]></title><description><![CDATA[<p dir="auto">My wr200cc/dt125r hybrid engine runs with lid cut off. I ran it also with the 125 engine. You just need to jet accordingly.</p>
]]></description><link>https://dt125r.co.uk/post/14939</link><guid isPermaLink="true">https://dt125r.co.uk/post/14939</guid><dc:creator><![CDATA[Louis-DT-WR]]></dc:creator><pubDate>Wed, 02 May 2018 14:44:28 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Wed, 02 May 2018 12:09:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darty" aria-label="Profile: Darty">@<bdi>Darty</bdi></a> here you can see</p>
]]></description><link>https://dt125r.co.uk/post/14934</link><guid isPermaLink="true">https://dt125r.co.uk/post/14934</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Wed, 02 May 2018 12:09:35 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 29 Mar 2018 20:47:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> look further up</p>
]]></description><link>https://dt125r.co.uk/post/14333</link><guid isPermaLink="true">https://dt125r.co.uk/post/14333</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Thu, 29 Mar 2018 20:47:48 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Fri, 23 Feb 2018 14:01:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fused" aria-label="Profile: fused">@<bdi>fused</bdi></a> True, but if the bike is purely used on the road then it will be fine, plus ssaves you buthering the box for more performance.</p>
]]></description><link>https://dt125r.co.uk/post/13623</link><guid isPermaLink="true">https://dt125r.co.uk/post/13623</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 23 Feb 2018 14:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Fri, 23 Feb 2018 13:02:27 GMT]]></title><description><![CDATA[<p dir="auto">You might want to keep the box/snorkel if you plan to go off road  a lot, through fords etc, as cone filters and the like are not so great at keeping water out of your engine</p>
]]></description><link>https://dt125r.co.uk/post/13620</link><guid isPermaLink="true">https://dt125r.co.uk/post/13620</guid><dc:creator><![CDATA[Fused]]></dc:creator><pubDate>Fri, 23 Feb 2018 13:02:27 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Fri, 23 Feb 2018 08:11:05 GMT]]></title><description><![CDATA[<p dir="auto">Seen on another forum that the snorkel off other DT's fit and they aren't as restrictive, I think I saw a guy with a DT175 one?<br />
I guess the DT200 or 230 would fit as well</p>
]]></description><link>https://dt125r.co.uk/post/13617</link><guid isPermaLink="true">https://dt125r.co.uk/post/13617</guid><dc:creator><![CDATA[finnerz89]]></dc:creator><pubDate>Fri, 23 Feb 2018 08:11:05 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 22 Feb 2018 21:50:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glynn123" aria-label="Profile: glynn123">@<bdi>glynn123</bdi></a> I'd just cut the whole lid off if it's already been cut.</p>
]]></description><link>https://dt125r.co.uk/post/13610</link><guid isPermaLink="true">https://dt125r.co.uk/post/13610</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 22 Feb 2018 21:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 22 Feb 2018 21:48:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> mines already slightly butchered haha, I have my snorkel removed so was thinking of just elongating the hole across, not cutting the whole lid, however I might just leave it for this summer.</p>
]]></description><link>https://dt125r.co.uk/post/13609</link><guid isPermaLink="true">https://dt125r.co.uk/post/13609</guid><dc:creator><![CDATA[Glynn123]]></dc:creator><pubDate>Thu, 22 Feb 2018 21:48:39 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 22 Feb 2018 21:30:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glynn123" aria-label="Profile: glynn123">@<bdi>glynn123</bdi></a> So I think it's absolutely criminal, however Rob @ Yamaha Skellerns Cheltenham tells me that these bikes are massively restricted by the air box and he encourages the cutting of them for performance sake. As said, I just run a pod filter as it means you don't butcher an OEM part.</p>
]]></description><link>https://dt125r.co.uk/post/13607</link><guid isPermaLink="true">https://dt125r.co.uk/post/13607</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 22 Feb 2018 21:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 22 Feb 2018 20:53:30 GMT]]></title><description><![CDATA[<p dir="auto">What's your opinions on cutting out the airbox lid Calum? I'm thinking of doing this myself, however maybe abit lean on stock carb with a full system and 250 main jet?</p>
]]></description><link>https://dt125r.co.uk/post/13606</link><guid isPermaLink="true">https://dt125r.co.uk/post/13606</guid><dc:creator><![CDATA[Glynn123]]></dc:creator><pubDate>Thu, 22 Feb 2018 20:53:30 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 22 Feb 2018 20:16:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irongamer727" aria-label="Profile: irongamer727">@<bdi>irongamer727</bdi></a> No box mate, pod filter, easier to jet, less restrictive.</p>
]]></description><link>https://dt125r.co.uk/post/13604</link><guid isPermaLink="true">https://dt125r.co.uk/post/13604</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 22 Feb 2018 20:16:23 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 22 Feb 2018 20:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> are you running the stock box?</p>
]]></description><link>https://dt125r.co.uk/post/13600</link><guid isPermaLink="true">https://dt125r.co.uk/post/13600</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Thu, 22 Feb 2018 20:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to Cutout acceptable? on Thu, 22 Feb 2018 08:00:08 GMT]]></title><description><![CDATA[<p dir="auto">Perfectly fine. Sir boxes on these are really restrictive.</p>
]]></description><link>https://dt125r.co.uk/post/13592</link><guid isPermaLink="true">https://dt125r.co.uk/post/13592</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 22 Feb 2018 08:00:08 GMT</pubDate></item></channel></rss>
