<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CRANK BEARINGS !!!]]></title><description><![CDATA[<p dir="auto">Hey can anyone recommend where to find the right bearing for my bottom end i have 88 bottom end and have bought 6305 sized bearings . then realise i have got the wrong ones and discovered i needed 6305R1 and since not been able to source them i have looked and found one set only but i am unsure if i should get them as it does not state they are c3 rated as the previous pair were .</p>
<p dir="auto">any help greatly appreciated</p>
<p dir="auto">jack</p>
]]></description><link>https://dt125r.co.uk/topic/1373/crank-bearings</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 00:21:14 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1373.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Mar 2018 22:46:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Sat, 02 Mar 2019 16:55:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dtr-nsr" aria-label="Profile: DTR-NSR">@<bdi>DTR-NSR</bdi></a> yes they are narrower. Found out the hard way years ago when I couldn't get my cases back together......</p>
]]></description><link>https://dt125r.co.uk/post/19938</link><guid isPermaLink="true">https://dt125r.co.uk/post/19938</guid><dc:creator><![CDATA[Nottsbiker]]></dc:creator><pubDate>Sat, 02 Mar 2019 16:55:55 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Sat, 02 Mar 2019 14:06:38 GMT]]></title><description><![CDATA[<p dir="auto">I believe there expensive due to being a oddball size, something .5mm wide I think.</p>
]]></description><link>https://dt125r.co.uk/post/19934</link><guid isPermaLink="true">https://dt125r.co.uk/post/19934</guid><dc:creator><![CDATA[DTR+NSR]]></dc:creator><pubDate>Sat, 02 Mar 2019 14:06:38 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Sat, 02 Mar 2019 00:14:37 GMT]]></title><description><![CDATA[<p dir="auto">fowlers part number is 93306-30556 and on this page it shows this part number 3rd one down just joined up<br />
<a href="http://www.athenaparts.com/eng/products/view/4827/bearing-6305ri-koyo" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.athenaparts.com/eng/products/view/4827/bearing-6305ri-koyo</a><br />
so might be worth ordering a set to see if they match up but looks promising</p>
]]></description><link>https://dt125r.co.uk/post/19927</link><guid isPermaLink="true">https://dt125r.co.uk/post/19927</guid><dc:creator><![CDATA[britshgigolo]]></dc:creator><pubDate>Sat, 02 Mar 2019 00:14:37 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Fri, 01 Mar 2019 23:41:52 GMT]]></title><description><![CDATA[<p dir="auto">looking on the this website <a href="http://www.athenaparts.com/eng/models/view/4453-section-25/yamaha-dt-125-r-re-x" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.athenaparts.com/eng/models/view/4453-section-25/yamaha-dt-125-r-re-x</a> it looks like they may be the size with out measuring a set of bearings it hard to say but if they are the right ones will save people some money or maybe i will order two and see if they will measure up to the spare engine i have in shed as did not keep the olds<br />
Main Bearing 	MS250620160YYK 	Bearing 6305ri - Koyo 	<br />
Dimensions 62.00x25.00x16.00</p>
]]></description><link>https://dt125r.co.uk/post/19926</link><guid isPermaLink="true">https://dt125r.co.uk/post/19926</guid><dc:creator><![CDATA[britshgigolo]]></dc:creator><pubDate>Fri, 01 Mar 2019 23:41:52 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Fri, 01 Mar 2019 23:21:28 GMT]]></title><description><![CDATA[<p dir="auto">i have a set my self just thought i would post up to see if the numbers matched i have searched the web and only found forgein page relaing to dtr but could not read it</p>
]]></description><link>https://dt125r.co.uk/post/19925</link><guid isPermaLink="true">https://dt125r.co.uk/post/19925</guid><dc:creator><![CDATA[britshgigolo]]></dc:creator><pubDate>Fri, 01 Mar 2019 23:21:28 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Fri, 01 Mar 2019 23:07:30 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.pjme.co.uk/acatalog/Yamaha_DT125R_Engine_Parts_Bott.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.pjme.co.uk/acatalog/Yamaha_DT125R_Engine_Parts_Bott.html</a></p>
]]></description><link>https://dt125r.co.uk/post/19924</link><guid isPermaLink="true">https://dt125r.co.uk/post/19924</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 01 Mar 2019 23:07:30 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Fri, 01 Mar 2019 23:06:50 GMT]]></title><description><![CDATA[<p dir="auto">Should be about £50 a set. They're an odd size and very expensive. PJME has them.</p>
<p dir="auto">If they're cheap, then they're probably the wrong bearings.</p>
]]></description><link>https://dt125r.co.uk/post/19923</link><guid isPermaLink="true">https://dt125r.co.uk/post/19923</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 01 Mar 2019 23:06:50 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Fri, 01 Mar 2019 22:42:47 GMT]]></title><description><![CDATA[<p dir="auto">i know this is old but did you find the right bearing number as think they might be this 6305r1sh29tcs35 but only got this nuumber from listing on ebay and maybe sombody that has changed them can say if they the right ones if so will work out a lot cheaper if they the right ones but they are the one pictured</p>
]]></description><link>https://dt125r.co.uk/post/19922</link><guid isPermaLink="true">https://dt125r.co.uk/post/19922</guid><dc:creator><![CDATA[britshgigolo]]></dc:creator><pubDate>Fri, 01 Mar 2019 22:42:47 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Fri, 30 Mar 2018 08:56:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> ah great thanks man really appreciated</p>
]]></description><link>https://dt125r.co.uk/post/14346</link><guid isPermaLink="true">https://dt125r.co.uk/post/14346</guid><dc:creator><![CDATA[jackthestripper]]></dc:creator><pubDate>Fri, 30 Mar 2018 08:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to CRANK BEARINGS !!! on Thu, 29 Mar 2018 23:27:39 GMT]]></title><description><![CDATA[<p dir="auto">Simply bearings, yeah the DT uses an odd sized bearing. They're expensive as well! IIRC they're overrated bearings meant to handle more power, hence their reliability.</p>
<p dir="auto">If you're uncertain, then grab them from PJME. Those guys know their shit and will sort you out.</p>
]]></description><link>https://dt125r.co.uk/post/14343</link><guid isPermaLink="true">https://dt125r.co.uk/post/14343</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 29 Mar 2018 23:27:39 GMT</pubDate></item></channel></rss>
