<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Slipping clutch after rebuild]]></title><description><![CDATA[<p dir="auto">I recently rebuilt my clutch after it was dragging and now it's slipping. I was curious to why this is. I am 100% positive i put the steels and plates in properly and aligned it all correctly. I am using a 10w30 mineral oil so I don't think that's the problem as I ran it before the rebuild. Maybe the pushrod is not adjusted? I heard you have to adjust them which I did not as I didn't see no such setting in the Haynes manual, would appreciate any help or information!!!</p>
]]></description><link>https://dt125r.co.uk/topic/1377/slipping-clutch-after-rebuild</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 18:00:53 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1377.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Apr 2018 10:04:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Slipping clutch after rebuild on Mon, 02 Apr 2018 12:05:38 GMT]]></title><description><![CDATA[<p dir="auto">Mine slipped with Castrol Magentec. I just use Castrol GTX Semi 5-30w</p>
]]></description><link>https://dt125r.co.uk/post/14372</link><guid isPermaLink="true">https://dt125r.co.uk/post/14372</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 02 Apr 2018 12:05:38 GMT</pubDate></item><item><title><![CDATA[Reply to Slipping clutch after rebuild on Mon, 02 Apr 2018 11:52:22 GMT]]></title><description><![CDATA[<p dir="auto">Not too sure what oil all the other guys are using but mineral oil made mine slip so used silkolene light gear oil instead, that worked a treat</p>
]]></description><link>https://dt125r.co.uk/post/14371</link><guid isPermaLink="true">https://dt125r.co.uk/post/14371</guid><dc:creator><![CDATA[Mitch_350z]]></dc:creator><pubDate>Mon, 02 Apr 2018 11:52:22 GMT</pubDate></item><item><title><![CDATA[Reply to Slipping clutch after rebuild on Mon, 02 Apr 2018 10:20:08 GMT]]></title><description><![CDATA[<p dir="auto">So the common one here i that one of the friction plates is about half the width of all the others and uses a compression ring in the middle. That must go on first.</p>
<p dir="auto">Assuming you've done that, then the clutch springs must be torqued up appropriately and within spec.</p>
<p dir="auto">The clutch MUST spend 24 hours soaked in oil prior to their installation, this means to take each clutch plate out on their own and bathe them in a layer of oil for 24 hours.</p>
<p dir="auto">The clutch is actuator by the cam arm, two push rods separated by the ball bearing.</p>
<p dir="auto">However, this is used to disengage the clutch, which wouldn't cause it slip.</p>
<p dir="auto">If it's been set so that it's never engaged, then this would be where you look.</p>
<p dir="auto">First starting at the clutch basket, you want to ensure the screw and nut have been adjusted appropriately.</p>
<p dir="auto">Once you're confident that's been done, then you adjust at the cam arm.</p>
<p dir="auto">And once that's done, you make your final amendments to the clutch perch.</p>
]]></description><link>https://dt125r.co.uk/post/14370</link><guid isPermaLink="true">https://dt125r.co.uk/post/14370</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 02 Apr 2018 10:20:08 GMT</pubDate></item></channel></rss>
