<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Electrical problems, help please]]></title><description><![CDATA[<p dir="auto">So after i went for a short ride, my electrical system just failed, nothing worked, so i changed the fuses 20Ampers were on it, so i replaced them with 20Ampers aswell. And now everything seems to be working other than the brake light and the indicators</p>
]]></description><link>https://dt125r.co.uk/topic/1419/electrical-problems-help-please</link><generator>RSS for Node</generator><lastBuildDate>Thu, 19 Nov 2026 06:23:43 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1419.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Apr 2018 13:30:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Electrical problems, help please on Sun, 29 Apr 2018 12:25:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> <a href="https://youtu.be/qK4GSDT89mM" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/qK4GSDT89mM</a> soo heres what's happening with the indicators. I put a wire on instead of the relay so it would keep lighting. It worked perfectly fine on the right side but on the left it didn't work, any ideas?</p>
]]></description><link>https://dt125r.co.uk/post/14854</link><guid isPermaLink="true">https://dt125r.co.uk/post/14854</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Sun, 29 Apr 2018 12:25:35 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Sat, 28 Apr 2018 10:33:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> no? But on other bikes it clicks</p>
]]></description><link>https://dt125r.co.uk/post/14844</link><guid isPermaLink="true">https://dt125r.co.uk/post/14844</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Sat, 28 Apr 2018 10:33:35 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Sat, 28 Apr 2018 10:21:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: bananper">@<bdi>bananper</bdi></a> It's not a car.</p>
]]></description><link>https://dt125r.co.uk/post/14843</link><guid isPermaLink="true">https://dt125r.co.uk/post/14843</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 28 Apr 2018 10:21:00 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Sat, 28 Apr 2018 10:14:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> the indicator should make a clicking sound when turned on shouldn't it?</p>
]]></description><link>https://dt125r.co.uk/post/14842</link><guid isPermaLink="true">https://dt125r.co.uk/post/14842</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Sat, 28 Apr 2018 10:14:00 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 19:17:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: bananper">@<bdi>bananper</bdi></a> Impedence test.</p>
]]></description><link>https://dt125r.co.uk/post/14837</link><guid isPermaLink="true">https://dt125r.co.uk/post/14837</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 19:17:54 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 19:15:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> How do i test if the rectifier is the problem?</p>
]]></description><link>https://dt125r.co.uk/post/14836</link><guid isPermaLink="true">https://dt125r.co.uk/post/14836</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 19:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 17:48:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: bananper">@<bdi>bananper</bdi></a> Cool, but as I say, there'll be an underlying issue you need to figure out else you'll just end up damaging components. Even the CDI.</p>
<p dir="auto">Based off you're fuzzy description, I'd suspect that a relay has gone open circuit, or more likely the rectifier has packed up.</p>
]]></description><link>https://dt125r.co.uk/post/14832</link><guid isPermaLink="true">https://dt125r.co.uk/post/14832</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 17:48:17 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 17:32:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> well now i took out the brake bulb, one string is working the other is not. And i think the turn signal relay is blown aswell</p>
]]></description><link>https://dt125r.co.uk/post/14831</link><guid isPermaLink="true">https://dt125r.co.uk/post/14831</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 17:32:48 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 17:21:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: bananper">@<bdi>bananper</bdi></a> What? Do you have a TZR?</p>
<p dir="auto">If the DT is 15 Amps, and you have a DT, then I'd strongly suggest putting in a 15 amp fuse.</p>
<p dir="auto">As I've said already, sounds like you have a dead short that you need to fix.</p>
]]></description><link>https://dt125r.co.uk/post/14829</link><guid isPermaLink="true">https://dt125r.co.uk/post/14829</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 17:21:22 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 17:10:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> i've looked into the haynes manual and it says that the TZR model has 20A fuses and the DT model has 15A fuses, can this be the cause?</p>
]]></description><link>https://dt125r.co.uk/post/14828</link><guid isPermaLink="true">https://dt125r.co.uk/post/14828</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 17:10:23 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 17:05:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> so one of the fuses seems to be blown</p>
]]></description><link>https://dt125r.co.uk/post/14827</link><guid isPermaLink="true">https://dt125r.co.uk/post/14827</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 17:05:48 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 15:43:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: bananper">@<bdi>bananper</bdi></a> What you talking about?</p>
<p dir="auto">I've said something probably went open circuit, hence why the fuse blown. It most likely blew the bulb at the same time. Fuses are exactly the best way to protect circuitary.</p>
<p dir="auto">I'm waiting on you to go and actually have a look to see if the fuse is blown.</p>
<p dir="auto">I think 20 amps is correct. It might have been 15 come to think of it.</p>
]]></description><link>https://dt125r.co.uk/post/14821</link><guid isPermaLink="true">https://dt125r.co.uk/post/14821</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 15:43:21 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 15:39:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> What's the right amperage then?</p>
]]></description><link>https://dt125r.co.uk/post/14820</link><guid isPermaLink="true">https://dt125r.co.uk/post/14820</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 15:39:30 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 15:27:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: bananper">@<bdi>bananper</bdi></a> You said you replaced it right? So it probably failed as it took out a bulb when it went open circuit.</p>
<p dir="auto">It's merely a suggestion, go and have a look.</p>
]]></description><link>https://dt125r.co.uk/post/14819</link><guid isPermaLink="true">https://dt125r.co.uk/post/14819</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 15:27:26 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 15:08:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> well so thats what's wrong? But there was 20A fuses on when i took them out and that have been working until now</p>
]]></description><link>https://dt125r.co.uk/post/14818</link><guid isPermaLink="true">https://dt125r.co.uk/post/14818</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 15:08:23 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 14:41:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: bananper">@<bdi>bananper</bdi></a> 20 amps will blow the bulb mate.</p>
]]></description><link>https://dt125r.co.uk/post/14817</link><guid isPermaLink="true">https://dt125r.co.uk/post/14817</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 14:41:40 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 14:00:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> nope, but which relay is which? And that doesn't really explain what happened to the brake light?</p>
]]></description><link>https://dt125r.co.uk/post/14816</link><guid isPermaLink="true">https://dt125r.co.uk/post/14816</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 14:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 13:52:27 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like the indicator relay has failed.</p>
<p dir="auto">You're not running any LED lights are you?</p>
]]></description><link>https://dt125r.co.uk/post/14813</link><guid isPermaLink="true">https://dt125r.co.uk/post/14813</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 13:52:27 GMT</pubDate></item><item><title><![CDATA[Reply to Electrical problems, help please on Fri, 27 Apr 2018 13:49:03 GMT]]></title><description><![CDATA[<p dir="auto">What happens when i turn on the indicator is just it lights up once and then turns of btw.</p>
]]></description><link>https://dt125r.co.uk/post/14812</link><guid isPermaLink="true">https://dt125r.co.uk/post/14812</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 27 Apr 2018 13:49:03 GMT</pubDate></item></channel></rss>
