<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rear suspension too hard.]]></title><description><![CDATA[<p dir="auto">Hi, figured out what is causing my DT to weave at high speeds and the rear suspension is way too hard compared to the front. It is a 2003 DT 125 R, with no one on the bike what is the rear sag roughly for a 2003 dt. On my bike with no one on it and the bike stood level if I pull up on the rear mudguard there is no sag at all not even a mm as when I pull up on the mudguard the bike comes off the floor. Is there any way to adjust the preload on the rear shock, how can I tell if there is a jack up kit<br />
on it.  thanks</p>
]]></description><link>https://dt125r.co.uk/topic/1421/rear-suspension-too-hard</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 16:12:29 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1421.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Apr 2018 16:53:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rear suspension too hard. on Sun, 29 Apr 2018 21:09:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/2stroketerry" aria-label="Profile: 2stroketerry">@<bdi>2stroketerry</bdi></a> well maybe my experience it bet my cat on it being the dog bone semi seized</p>
]]></description><link>https://dt125r.co.uk/post/14864</link><guid isPermaLink="true">https://dt125r.co.uk/post/14864</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Sun, 29 Apr 2018 21:09:03 GMT</pubDate></item><item><title><![CDATA[Reply to Rear suspension too hard. on Sun, 29 Apr 2018 17:55:15 GMT]]></title><description><![CDATA[<p dir="auto">Just got the bike recently and working outdoors so haven't had the chance to do many jobs on it yet due to the weather.</p>
]]></description><link>https://dt125r.co.uk/post/14861</link><guid isPermaLink="true">https://dt125r.co.uk/post/14861</guid><dc:creator><![CDATA[2stroketerry]]></dc:creator><pubDate>Sun, 29 Apr 2018 17:55:15 GMT</pubDate></item><item><title><![CDATA[Reply to Rear suspension too hard. on Sun, 29 Apr 2018 16:06:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/2stroketerry" aria-label="Profile: 2stroketerry">@<bdi>2stroketerry</bdi></a> have you cleaned and greased your dog bone bushings mine were dry and full of dirt so my rear suspension was non existent im talking nothing at all</p>
]]></description><link>https://dt125r.co.uk/post/14858</link><guid isPermaLink="true">https://dt125r.co.uk/post/14858</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Sun, 29 Apr 2018 16:06:43 GMT</pubDate></item><item><title><![CDATA[Reply to Rear suspension too hard. on Sat, 28 Apr 2018 07:41:51 GMT]]></title><description><![CDATA[<p dir="auto">Theres a lot of preload on that spring, compared to the picture i found. So thats why it stiff, and the rear is higher in the air than it should.</p>
<p dir="auto">Its hard to tell if dogbones are stock from a pic, but they look like it.</p>
]]></description><link>https://dt125r.co.uk/post/14839</link><guid isPermaLink="true">https://dt125r.co.uk/post/14839</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Sat, 28 Apr 2018 07:41:51 GMT</pubDate></item><item><title><![CDATA[Reply to Rear suspension too hard. on Fri, 27 Apr 2018 19:31:53 GMT]]></title><description><![CDATA[<p dir="auto">Here is my rear suspension, are the dog bones standard as my rear suspension is too high.<img src="https://i.imgur.com/DsiuogA.jpg" alt="0_1524857475620_1.jpg" class="img-markdown  img-fluid" /><br />
<img src="https://i.imgur.com/tSSIJHR.jpg" alt="0_1524857489944_2.jpg" class="img-markdown  img-fluid" /></p>
]]></description><link>https://dt125r.co.uk/post/14838</link><guid isPermaLink="true">https://dt125r.co.uk/post/14838</guid><dc:creator><![CDATA[2stroketerry]]></dc:creator><pubDate>Fri, 27 Apr 2018 19:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to Rear suspension too hard. on Fri, 27 Apr 2018 18:50:44 GMT]]></title><description><![CDATA[<p dir="auto">Static sag is 10% of total travel of the rear shock, race sag is 30%.- This is a very good rule of thump for every dirtbike/dualsport/mx bike out there.</p>
<p dir="auto">My dtr has spring preload at the bottom. its easier to remove the shock to adjust it, however yours could be damaged, it the preload is wound op a lot!<br />
<a href="http://www.motor-bike-breakers.co.uk/wp-content/uploads/2014/12/Yamaha-DTR-125-Rear-Shock-absorber-Spare-Parts-Motor-Cycle-Breaking.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.motor-bike-breakers.co.uk/wp-content/uploads/2014/12/Yamaha-DTR-125-Rear-Shock-absorber-Spare-Parts-Motor-Cycle-Breaking.jpg</a></p>
]]></description><link>https://dt125r.co.uk/post/14833</link><guid isPermaLink="true">https://dt125r.co.uk/post/14833</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Fri, 27 Apr 2018 18:50:44 GMT</pubDate></item><item><title><![CDATA[Reply to Rear suspension too hard. on Fri, 27 Apr 2018 17:22:55 GMT]]></title><description><![CDATA[<p dir="auto">As far as I'm aware, DT shocks were always piss poor and non-adjustable.</p>
<p dir="auto">That said, I've never had any issues with my RE, always felt the shock was adequate enough for road use.</p>
<p dir="auto">I don't think they're serviceable either, so it'll have to be a replacement one.</p>
<p dir="auto">Happy to be corrected...</p>
]]></description><link>https://dt125r.co.uk/post/14830</link><guid isPermaLink="true">https://dt125r.co.uk/post/14830</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 27 Apr 2018 17:22:55 GMT</pubDate></item></channel></rss>
