<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wr200 engine in dt frame?]]></title><description><![CDATA[<p dir="auto">Will a wr200 engine fit in a dt125re frame?<br />
Also i've read somewhere that the fmf from wr200 would fit straight on a dtr, is this true?</p>
]]></description><link>https://dt125r.co.uk/topic/1432/wr200-engine-in-dt-frame</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 16:23:38 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1432.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 May 2018 14:20:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wr200 engine in dt frame? on Fri, 13 Jul 2018 15:25:50 GMT]]></title><description><![CDATA[<p dir="auto">@jamesrandall93 id recommend you to get arrow/gianelli if you want the best performance and straight fit</p>
]]></description><link>https://dt125r.co.uk/post/16644</link><guid isPermaLink="true">https://dt125r.co.uk/post/16644</guid><dc:creator><![CDATA[Bananper]]></dc:creator><pubDate>Fri, 13 Jul 2018 15:25:50 GMT</pubDate></item><item><title><![CDATA[Reply to Wr200 engine in dt frame? on Fri, 13 Jul 2018 10:29:56 GMT]]></title><description><![CDATA[<p dir="auto">@louis-james   how did you manage it and was it complicated i dont want a dep like every one else</p>
]]></description><link>https://dt125r.co.uk/post/16641</link><guid isPermaLink="true">https://dt125r.co.uk/post/16641</guid><dc:creator><![CDATA[Randall]]></dc:creator><pubDate>Fri, 13 Jul 2018 10:29:56 GMT</pubDate></item><item><title><![CDATA[Reply to Wr200 engine in dt frame? on Tue, 08 May 2018 14:20:02 GMT]]></title><description><![CDATA[<p dir="auto">I have a wr200 exhaust on a dt125r Frame ,you need to modify a few things</p>
]]></description><link>https://dt125r.co.uk/post/15087</link><guid isPermaLink="true">https://dt125r.co.uk/post/15087</guid><dc:creator><![CDATA[Louis-DT-WR]]></dc:creator><pubDate>Tue, 08 May 2018 14:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to Wr200 engine in dt frame? on Mon, 07 May 2018 15:56:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananper" aria-label="Profile: Bananper">@<bdi>Bananper</bdi></a></p>
<p dir="auto">True.</p>
<p dir="auto">Just need spacers on the Forward Mounts and between the swingarm,</p>
<p dir="auto">Also need to modify the cylinder braces,</p>
<p dir="auto">There are also some clearance issues if you decided to run WR200 radiator split pipe for Twin Rads,</p>
]]></description><link>https://dt125r.co.uk/post/15059</link><guid isPermaLink="true">https://dt125r.co.uk/post/15059</guid><dc:creator><![CDATA[Darty]]></dc:creator><pubDate>Mon, 07 May 2018 15:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to Wr200 engine in dt frame? on Mon, 07 May 2018 15:25:40 GMT]]></title><description><![CDATA[<p dir="auto">If it fits the DTR frame, it'll fit the DTRE frame. Engine wise.</p>
]]></description><link>https://dt125r.co.uk/post/15058</link><guid isPermaLink="true">https://dt125r.co.uk/post/15058</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 07 May 2018 15:25:40 GMT</pubDate></item><item><title><![CDATA[Reply to Wr200 engine in dt frame? on Mon, 07 May 2018 15:20:53 GMT]]></title><description><![CDATA[<p dir="auto">I think the Wr200 engine is a direct fit on the old frame, I believe I read that somewhere, but can't say for sure on the DTRE frame...</p>
]]></description><link>https://dt125r.co.uk/post/15057</link><guid isPermaLink="true">https://dt125r.co.uk/post/15057</guid><dc:creator><![CDATA[Minia]]></dc:creator><pubDate>Mon, 07 May 2018 15:20:53 GMT</pubDate></item></channel></rss>
