<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Best Bearing Tools]]></title><description><![CDATA[<p dir="auto">Dear Tools -<br />
How are we all??? LOL</p>
<p dir="auto">I'm just wondering which tools you guys use to remove and install your ball bearings with???</p>
]]></description><link>https://dt125r.co.uk/topic/1443/best-bearing-tools</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 16:33:28 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1443.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 May 2018 21:36:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Best Bearing Tools on Fri, 11 May 2018 08:51:33 GMT]]></title><description><![CDATA[<p dir="auto">A drift for wheelbearings, I make a homemade press for the linkage bearings with a threaded rod, washers and nuts.</p>
<p dir="auto">I once removed a bearing using bread aswell (go youtube it) just to try it :grinning_face_with_smiling_eyes:</p>
]]></description><link>https://dt125r.co.uk/post/15185</link><guid isPermaLink="true">https://dt125r.co.uk/post/15185</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Fri, 11 May 2018 08:51:33 GMT</pubDate></item><item><title><![CDATA[Reply to Best Bearing Tools on Thu, 10 May 2018 22:54:19 GMT]]></title><description><![CDATA[<p dir="auto">Headset bearings I used a long m20 nut and bolt with some packing washers etc, pulled straight in that way.</p>
<p dir="auto">And wheel bearings I used a heat gun and then an aluminum drift I think. Might've even been timber actually. If you get the hubs warm enough then they don't need much encouragement at all. You can also freeze your bearings for 24 hours before fitting.</p>
]]></description><link>https://dt125r.co.uk/post/15183</link><guid isPermaLink="true">https://dt125r.co.uk/post/15183</guid><dc:creator><![CDATA[finnerz89]]></dc:creator><pubDate>Thu, 10 May 2018 22:54:19 GMT</pubDate></item><item><title><![CDATA[Reply to Best Bearing Tools on Thu, 10 May 2018 22:22:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: ninja">@<bdi>ninja</bdi></a> It's actually the best way to do them, as you put no stress or strain on the bearing and don't risk damaging the crank journals.</p>
]]></description><link>https://dt125r.co.uk/post/15181</link><guid isPermaLink="true">https://dt125r.co.uk/post/15181</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 10 May 2018 22:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to Best Bearing Tools on Thu, 10 May 2018 22:21:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> DAYUM!!! COOL trick and I must say what a very clean oven too. Does the misses know about your roasted crank case sorbets??? :smiling_face_with_open_mouth:</p>
]]></description><link>https://dt125r.co.uk/post/15180</link><guid isPermaLink="true">https://dt125r.co.uk/post/15180</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Thu, 10 May 2018 22:21:02 GMT</pubDate></item><item><title><![CDATA[Reply to Best Bearing Tools on Thu, 10 May 2018 22:18:35 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.imgur.com/ZZvttfy.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">200 degrees, bearings drop straight in.</p>
]]></description><link>https://dt125r.co.uk/post/15179</link><guid isPermaLink="true">https://dt125r.co.uk/post/15179</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 10 May 2018 22:18:35 GMT</pubDate></item><item><title><![CDATA[Reply to Best Bearing Tools on Thu, 10 May 2018 22:12:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> Well headset and wheels mainly. And how do use use an oven??? :confused_face:</p>
]]></description><link>https://dt125r.co.uk/post/15176</link><guid isPermaLink="true">https://dt125r.co.uk/post/15176</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Thu, 10 May 2018 22:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to Best Bearing Tools on Thu, 10 May 2018 22:11:02 GMT]]></title><description><![CDATA[<p dir="auto">What type of bearings bud?</p>
<p dir="auto">Usually I use an oven and no press for engine stuff.</p>
]]></description><link>https://dt125r.co.uk/post/15174</link><guid isPermaLink="true">https://dt125r.co.uk/post/15174</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 10 May 2018 22:11:02 GMT</pubDate></item></channel></rss>
