<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Different needle bearings and gudgeon pins.]]></title><description><![CDATA[<p dir="auto"><a href="https://imgur.com/a/s0qOtC5" target="_blank" rel="noopener noreferrer nofollow ugc">https://imgur.com/a/s0qOtC5</a></p>
<p dir="auto">One cheap one "expensive"?<br />
I guess the thinner is the more expensive.<br />
Interesting though.</p>
]]></description><link>https://dt125r.co.uk/topic/1488/different-needle-bearings-and-gudgeon-pins</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 09:57:24 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1488.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Jun 2018 22:35:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Different needle bearings and gudgeon pins. on Sun, 10 Jun 2018 10:11:11 GMT]]></title><description><![CDATA[<p dir="auto">Never really looked into it to be fair.</p>
<p dir="auto">The load on the gudgeon and small end probably is not that great when compared with the crank pin.</p>
<p dir="auto">I'd ensure you use the small end for that gudgeon. And never reuse gudgeon's and small ends, for their cost they are jut easy to renew.</p>
]]></description><link>https://dt125r.co.uk/post/15816</link><guid isPermaLink="true">https://dt125r.co.uk/post/15816</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 10 Jun 2018 10:11:11 GMT</pubDate></item><item><title><![CDATA[Reply to Different needle bearings and gudgeon pins. on Sat, 09 Jun 2018 22:22:13 GMT]]></title><description><![CDATA[<p dir="auto">Gudgeon pins <a href="https://imgur.com/gallery/qjjsHsU" target="_blank" rel="noopener noreferrer nofollow ugc">https://imgur.com/gallery/qjjsHsU</a></p>
<p dir="auto">So I'm also comparing the different gudgeon pins, one is 1mm linger and thinner. (It came with the forged original piston and thinner needle bearing).</p>
<p dir="auto">Is thinner stuff a sign of better quality in this case?</p>
]]></description><link>https://dt125r.co.uk/post/15815</link><guid isPermaLink="true">https://dt125r.co.uk/post/15815</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Sat, 09 Jun 2018 22:22:13 GMT</pubDate></item></channel></rss>
