<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Exhaust 'recovery pipe' got loose during high rev]]></title><description><![CDATA[<p dir="auto">Heya!<br />
In my 2004 DT 125RE there's a small pipe connected to the exhaust before the baloon thatdisconnected while riding!</p>
<p dir="auto">There's exhaust fumes coming out from there too now, and it is way noisier since it is right after the cylinder. What could have caused it? Should i just put it back and tight the screw without Concern? Also, what is it? It is a steel/alu pipe that goes in the engine - some kind of recovery system? I am not familiar with the exhaust systems of 2 stroke engines.</p>
<p dir="auto">Thanks in advance!<br />
Pires</p>
]]></description><link>https://dt125r.co.uk/topic/1607/exhaust-recovery-pipe-got-loose-during-high-rev</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 03:46:59 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1607.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Aug 2018 21:03:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Exhaust 'recovery pipe' got loose during high rev on Tue, 21 Aug 2018 09:12:48 GMT]]></title><description><![CDATA[<p dir="auto">I welded it shut</p>
]]></description><link>https://dt125r.co.uk/post/17023</link><guid isPermaLink="true">https://dt125r.co.uk/post/17023</guid><dc:creator><![CDATA[Irongamer727]]></dc:creator><pubDate>Tue, 21 Aug 2018 09:12:48 GMT</pubDate></item><item><title><![CDATA[Reply to Exhaust 'recovery pipe' got loose during high rev on Mon, 20 Aug 2018 23:38:56 GMT]]></title><description><![CDATA[<p dir="auto">It takes fresh air from the air box and routes it into the exhaust. As stated it's for emissions and doesn't affect performance either way.</p>
<p dir="auto">If it comes off again don't run the bike as you run the risk of running seriously lean like that.</p>
]]></description><link>https://dt125r.co.uk/post/17022</link><guid isPermaLink="true">https://dt125r.co.uk/post/17022</guid><dc:creator><![CDATA[finnerz89]]></dc:creator><pubDate>Mon, 20 Aug 2018 23:38:56 GMT</pubDate></item><item><title><![CDATA[Reply to Exhaust 'recovery pipe' got loose during high rev on Mon, 20 Aug 2018 23:17:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugabugas" aria-label="Profile: bugabugas">@<bdi>bugabugas</bdi></a> Upload some pics dude, it's 100% easier than trying to describe things. <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--wink" style="height:1.4em;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://dt125r.co.uk/post/17021</link><guid isPermaLink="true">https://dt125r.co.uk/post/17021</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Mon, 20 Aug 2018 23:17:24 GMT</pubDate></item><item><title><![CDATA[Reply to Exhaust 'recovery pipe' got loose during high rev on Mon, 20 Aug 2018 21:55:38 GMT]]></title><description><![CDATA[<p dir="auto">Pretty sure they're an emissions system on the later DTs, I'd block it off to be honest or change to a different exhaust system, doesn't help the engine in any way.</p>
]]></description><link>https://dt125r.co.uk/post/17019</link><guid isPermaLink="true">https://dt125r.co.uk/post/17019</guid><dc:creator><![CDATA[Glynn123]]></dc:creator><pubDate>Mon, 20 Aug 2018 21:55:38 GMT</pubDate></item><item><title><![CDATA[Reply to Exhaust 'recovery pipe' got loose during high rev on Mon, 20 Aug 2018 21:22:26 GMT]]></title><description><![CDATA[<p dir="auto">Small update: the hole in the pipe was clogged with coal-like residue and that was probably what pushed the pipe away while I was high revving the engine.<br />
Unclogged it and sticked it back in and I guess it is fine now as the noise seems as it used to. Still waiting for an explanation about the function of the exhaust recovery! <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f605.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--sweat_smile" style="height:1.4em;width:auto;vertical-align:middle" title="😅" alt="😅" /><br />
Pires</p>
]]></description><link>https://dt125r.co.uk/post/17017</link><guid isPermaLink="true">https://dt125r.co.uk/post/17017</guid><dc:creator><![CDATA[bugabugas]]></dc:creator><pubDate>Mon, 20 Aug 2018 21:22:26 GMT</pubDate></item></channel></rss>
