<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cylinder head]]></title><description><![CDATA[<p dir="auto">Is there anything that can be done to the head to improve the performance of the motor?  I've had a look through a few topics but can't see anything, just asking as my heads off to check the bore and piston and to get the plug hole helicoiled.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://dt125r.co.uk/topic/1662/cylinder-head</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 23:27:44 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1662.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Sep 2018 10:19:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cylinder head on Sun, 23 Sep 2018 11:17:51 GMT]]></title><description><![CDATA[<p dir="auto">Cheers, I'll call around and see if its cheaper than a big bore kit</p>
]]></description><link>https://dt125r.co.uk/post/17465</link><guid isPermaLink="true">https://dt125r.co.uk/post/17465</guid><dc:creator><![CDATA[Bluestoesonnose]]></dc:creator><pubDate>Sun, 23 Sep 2018 11:17:51 GMT</pubDate></item><item><title><![CDATA[Reply to Cylinder head on Sun, 23 Sep 2018 11:02:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluestoesonnose" aria-label="Profile: Bluestoesonnose">@<bdi>Bluestoesonnose</bdi></a> You can get the engine ported and tuned to make more power in the mid range, rather than peak power.</p>
<p dir="auto">Again, speaking to a tuner will be able to highlight what needs to be done.</p>
<p dir="auto">I don't know if he's still knocking about, but Mick Abbey might be able to help.</p>
<p dir="auto">When I spoke to him last, he provided free consultation, then I sent the barrel, powervalve and head off to him to work his magic. But he said it would be pointless without an aftermarket ignition system.</p>
]]></description><link>https://dt125r.co.uk/post/17464</link><guid isPermaLink="true">https://dt125r.co.uk/post/17464</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 23 Sep 2018 11:02:11 GMT</pubDate></item><item><title><![CDATA[Reply to Cylinder head on Sun, 23 Sep 2018 10:56:38 GMT]]></title><description><![CDATA[<p dir="auto">Many thanks, do you know anyone reliable and proven I could contact?</p>
<p dir="auto">Got a DEP system and Zeel CDI, only looking for it to pull a bit harder not rev higher, make it more usable on the road.</p>
]]></description><link>https://dt125r.co.uk/post/17463</link><guid isPermaLink="true">https://dt125r.co.uk/post/17463</guid><dc:creator><![CDATA[Bluestoesonnose]]></dc:creator><pubDate>Sun, 23 Sep 2018 10:56:38 GMT</pubDate></item><item><title><![CDATA[Reply to Cylinder head on Sun, 23 Sep 2018 10:53:09 GMT]]></title><description><![CDATA[<p dir="auto">Yeah. The head is where the majority of the power is made. So yes. you can have the head reworked to alter the squishband.</p>
<p dir="auto">Really you need to speak to a tuner to understand what it is you're after, where you want the power to be made and what ignition setup you're running.</p>
]]></description><link>https://dt125r.co.uk/post/17462</link><guid isPermaLink="true">https://dt125r.co.uk/post/17462</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 23 Sep 2018 10:53:09 GMT</pubDate></item></channel></rss>
