<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Loctite or no Loctite, that is the question]]></title><description><![CDATA[<p dir="auto">What's the thoughts on using Loctite on the barrel and head studs, I'd normally use a dab of grease but everything I've taken off has had tread lock on it?</p>
]]></description><link>https://dt125r.co.uk/topic/1737/loctite-or-no-loctite-that-is-the-question</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 19:57:00 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1737.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Nov 2018 09:15:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sun, 11 Nov 2018 19:43:47 GMT]]></title><description><![CDATA[<p dir="auto">Stuff inside the engine cases I always use loctite. Last thing you want is a screw coming loose and rattling around your clutch or something.</p>
<p dir="auto">External stuff I don't bother so much, as that's easy to enough to spot and rectify.</p>
]]></description><link>https://dt125r.co.uk/post/18176</link><guid isPermaLink="true">https://dt125r.co.uk/post/18176</guid><dc:creator><![CDATA[finnerz89]]></dc:creator><pubDate>Sun, 11 Nov 2018 19:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sun, 11 Nov 2018 01:52:42 GMT]]></title><description><![CDATA[<p dir="auto">Personally I've never bothered with it, just go around the bike check everything is fine every once in a while. You should be doing that anyway to be honest.</p>
]]></description><link>https://dt125r.co.uk/post/18164</link><guid isPermaLink="true">https://dt125r.co.uk/post/18164</guid><dc:creator><![CDATA[Minia]]></dc:creator><pubDate>Sun, 11 Nov 2018 01:52:42 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 19:27:38 GMT]]></title><description><![CDATA[<p dir="auto">I've always used loctite 2700 when fitting head studs to a barrel, as per my official Honda nsr manual.</p>
]]></description><link>https://dt125r.co.uk/post/18159</link><guid isPermaLink="true">https://dt125r.co.uk/post/18159</guid><dc:creator><![CDATA[DTR+NSR]]></dc:creator><pubDate>Sat, 10 Nov 2018 19:27:38 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 18:27:29 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, as I said, I didn't bother with the DT.</p>
]]></description><link>https://dt125r.co.uk/post/18158</link><guid isPermaLink="true">https://dt125r.co.uk/post/18158</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 10 Nov 2018 18:27:29 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 12:38:18 GMT]]></title><description><![CDATA[<p dir="auto">Shouldn't be an issue, been using it on other motorcycles for years, it's what it's designed for.  And I'm only holding on the barrel and head studs with it</p>
]]></description><link>https://dt125r.co.uk/post/18156</link><guid isPermaLink="true">https://dt125r.co.uk/post/18156</guid><dc:creator><![CDATA[Bluestoesonnose]]></dc:creator><pubDate>Sat, 10 Nov 2018 12:38:18 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 12:17:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: NINJA">@<bdi>NINJA</bdi></a> Vibrations and the fact it's submersed in hot oil. Meaning the ally expands, seeps oil in, and the vibrations cause the bolts to wriggle lose.</p>
<p dir="auto">The bolts shouldn't be tightend up that much. 10-15Nm. So yeah Loctite is pretty important.</p>
]]></description><link>https://dt125r.co.uk/post/18155</link><guid isPermaLink="true">https://dt125r.co.uk/post/18155</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 10 Nov 2018 12:17:12 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 12:16:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: NINJA">@<bdi>NINJA</bdi></a> shouldn't be an issue as this stuff is for engines</p>
]]></description><link>https://dt125r.co.uk/post/18154</link><guid isPermaLink="true">https://dt125r.co.uk/post/18154</guid><dc:creator><![CDATA[Bluestoesonnose]]></dc:creator><pubDate>Sat, 10 Nov 2018 12:16:54 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 11:56:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluestoesonnose" aria-label="Profile: Bluestoesonnose">@<bdi>Bluestoesonnose</bdi></a> I'm not sure why any threadlock is required on engine bolts, as <a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> has stated heat is the problem which will cause it to melt. I was always under the impression that you just tightened them up to the correct torque settings and be done with them???</p>
]]></description><link>https://dt125r.co.uk/post/18153</link><guid isPermaLink="true">https://dt125r.co.uk/post/18153</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Sat, 10 Nov 2018 11:56:54 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 11:42:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluestoesonnose" aria-label="Profile: Bluestoesonnose">@<bdi>Bluestoesonnose</bdi></a> Oh ryt, it wants to be temperature resistent, else what's the point. It'll just melt.</p>
<p dir="auto">Loctite specify various types of grades.</p>
]]></description><link>https://dt125r.co.uk/post/18152</link><guid isPermaLink="true">https://dt125r.co.uk/post/18152</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 10 Nov 2018 11:42:11 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 11:32:20 GMT]]></title><description><![CDATA[<p dir="auto">Just nutloc</p>
]]></description><link>https://dt125r.co.uk/post/18151</link><guid isPermaLink="true">https://dt125r.co.uk/post/18151</guid><dc:creator><![CDATA[Bluestoesonnose]]></dc:creator><pubDate>Sat, 10 Nov 2018 11:32:20 GMT</pubDate></item><item><title><![CDATA[Reply to Loctite or no Loctite, that is the question on Sat, 10 Nov 2018 09:36:08 GMT]]></title><description><![CDATA[<p dir="auto">Good question.</p>
<p dir="auto">I didn't on my DT but did on my RS. Any engine component I'd say loctite it.</p>
<p dir="auto">What compound will you be using?</p>
]]></description><link>https://dt125r.co.uk/post/18150</link><guid isPermaLink="true">https://dt125r.co.uk/post/18150</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 10 Nov 2018 09:36:08 GMT</pubDate></item></channel></rss>
