<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tuning my carb - which carb model, and types of jets?]]></title><description><![CDATA[<p dir="auto">Hi!<br />
Haven't been very active on the DT since I had the engine rebuild in the winther - i'm about to tune the carburetor since I added the Gianelli full system exhaust, de-restricted the airbox and had the barrel re-bored to oversize. BUT - i'm having a hard time figuring out which jet is what, and precise what model my carb is - in the Haynes manuel the VM26SS are described, but I don't think it is the same as mine, when I look at the illustrations/pictures - as far as I can see, mine is a VM28, can anyone confirm this?</p>
<p dir="auto">And about the jets - in Calums guide, there is described a needle jet, pilot jet and main jet. I can only seem to find 2 types of jets, the main jet and a pilot/needle jet (which one is it?) I can't follow the guide before I figure this out, so I really hope you guys can help me out :-)</p>
<p dir="auto"><img src="http://imgur.com/uUBEiX3" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="http://imgur.com/xhSffgF" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="http://imgur.com/f2MZh0z" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/topic/175/tuning-my-carb-which-carb-model-and-types-of-jets</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 20:27:56 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/175.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Apr 2016 16:21:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tuning my carb - which carb model, and types of jets? on Thu, 28 Apr 2016 22:15:21 GMT]]></title><description><![CDATA[<p dir="auto">Ah - thanks, now it starts to make sense. Been fiddling with it this afternoon and it seems to run great with a 260 main jet and 30 pilot jet - the only thing I wanted to achieve is reliabilty, making sure it not runs to lean, not to maximize performance..</p>
]]></description><link>https://dt125r.co.uk/post/1427</link><guid isPermaLink="true">https://dt125r.co.uk/post/1427</guid><dc:creator><![CDATA[MDN91]]></dc:creator><pubDate>Thu, 28 Apr 2016 22:15:21 GMT</pubDate></item><item><title><![CDATA[Reply to Tuning my carb - which carb model, and types of jets? on Wed, 27 Apr 2016 21:54:45 GMT]]></title><description><![CDATA[<p dir="auto">It doesn't make sense for a reason mate. It probably doesn't apply. Visually I'd say the needle jet has been substituted for main jet. The principles in that guide will help you tune any carb.</p>
<p dir="auto">But you don't start with the needle. I'd have to reread the guide.</p>
<p dir="auto">But can I ask what you are trying the achieve. Your mods won'won't change the jetting that much. There is no airbox restriction.  Hacking away at the air box is not a derestriction, as it upsets the air flow andn stall the flow. Hence why they run a smooth snorkel to allow safe passage into the their box. Remember even GP bikes use airbox and snorkels, for a good reason.</p>
]]></description><link>https://dt125r.co.uk/post/1417</link><guid isPermaLink="true">https://dt125r.co.uk/post/1417</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 27 Apr 2016 21:54:45 GMT</pubDate></item><item><title><![CDATA[Reply to Tuning my carb - which carb model, and types of jets? on Wed, 27 Apr 2016 13:53:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Thanks - but I'll have to admit that i'm still a tiny bit confused, the first step on the guide you posted is to "DETERMINE THE CORRECT NEEDLE AND OR NEEDLE JET." - I understand what the needle is and what it does, but what about the needle jet - where is it placed on my carb? The only jets I have bought to choose from are the pilot jets (blue on my pic) and main jets (red on my pic). These rest of the guide I think i'll manage, but the first bit confuses me. I wish I could find a specific guide for my carb, since most including the one in the Haynes model are about these older types of carbs, I guess.. And again, thanks for your help..</p>
]]></description><link>https://dt125r.co.uk/post/1410</link><guid isPermaLink="true">https://dt125r.co.uk/post/1410</guid><dc:creator><![CDATA[MDN91]]></dc:creator><pubDate>Wed, 27 Apr 2016 13:53:28 GMT</pubDate></item><item><title><![CDATA[Reply to Tuning my carb - which carb model, and types of jets? on Tue, 26 Apr 2016 20:11:42 GMT]]></title><description><![CDATA[<p dir="auto">FYI not my guide copied and pasted it from the Web.  I thought it was very useful.</p>
<p dir="auto">Very early DT'S will be 26mm.</p>
<p dir="auto">Later ones, the majority are miking 28mm flat slides</p>
<p dir="auto">The needle and main jet. The needle attaches to the throttle slide and it falls I to the  main jet. The needle controls how much of the main jet is exposed. The needle will do the majority of throttle openings.</p>
]]></description><link>https://dt125r.co.uk/post/1405</link><guid isPermaLink="true">https://dt125r.co.uk/post/1405</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 26 Apr 2016 20:11:42 GMT</pubDate></item></channel></rss>
