<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[wiring ignitech]]></title><description><![CDATA[<p dir="auto">has anyone wired an ignitech cdi direct to your battery?.my one seems to be draining it.<br />
if i wire it to the ignition which wire would i splice into.its a 6 wire ignition and im guessing red or brown or is there another switched source i can tap into.</p>
]]></description><link>https://dt125r.co.uk/topic/1783/wiring-ignitech</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 18:38:15 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1783.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Jan 2019 15:37:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to wiring ignitech on Fri, 15 Mar 2019 08:59:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/admiral323" aria-label="Profile: admiral323">@<bdi>admiral323</bdi></a> just an update on this issue incase it helps anybody else.i spliced the red wire from the ignitech into the brown coming from the ignition and have never had a problem again</p>
]]></description><link>https://dt125r.co.uk/post/20079</link><guid isPermaLink="true">https://dt125r.co.uk/post/20079</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Fri, 15 Mar 2019 08:59:35 GMT</pubDate></item><item><title><![CDATA[Reply to wiring ignitech on Sun, 06 Jan 2019 16:31:38 GMT]]></title><description><![CDATA[<p dir="auto">yes asking ignitech probably the best idea.thanks for the replies.appreciated</p>
]]></description><link>https://dt125r.co.uk/post/18898</link><guid isPermaLink="true">https://dt125r.co.uk/post/18898</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:31:38 GMT</pubDate></item><item><title><![CDATA[Reply to wiring ignitech on Sun, 06 Jan 2019 16:28:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/admiral323" aria-label="Profile: admiral323">@<bdi>admiral323</bdi></a> No idea. Doesn't sound right.</p>
<p dir="auto">I wouldn't be wiring the ignitech off the battery unprotected if I were you.</p>
<p dir="auto">You would want to run it off a switch line which is fuse protected to reduce the risk of damaging your equipment. If you're unsure then pay a professional to fit it, or ask Ignitech themselves. As said, I am not familiar with the system to provide any guidance.</p>
]]></description><link>https://dt125r.co.uk/post/18897</link><guid isPermaLink="true">https://dt125r.co.uk/post/18897</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:28:23 GMT</pubDate></item><item><title><![CDATA[Reply to wiring ignitech on Sun, 06 Jan 2019 16:25:40 GMT]]></title><description><![CDATA[<p dir="auto">changed the battery thinking it was that but its done the same to the new so think it must be drawing power some how.<br />
im thinking of running the wire up to the ignition and splicing it into the brown wire.think that should cut the power to it from the ignition.does that sound right?</p>
]]></description><link>https://dt125r.co.uk/post/18896</link><guid isPermaLink="true">https://dt125r.co.uk/post/18896</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:25:40 GMT</pubDate></item><item><title><![CDATA[Reply to wiring ignitech on Sun, 06 Jan 2019 16:14:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/admiral323" aria-label="Profile: admiral323">@<bdi>admiral323</bdi></a> It must have a remote switch, and then a direct feed off the battery. I.E. it shouldn't be on all the time. Otherwise that will drain your battery?</p>
<p dir="auto">I'm not familiar with it, I just use Zeeltronic ignition system which is plug and play.</p>
]]></description><link>https://dt125r.co.uk/post/18895</link><guid isPermaLink="true">https://dt125r.co.uk/post/18895</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:14:07 GMT</pubDate></item><item><title><![CDATA[Reply to wiring ignitech on Sun, 06 Jan 2019 16:00:19 GMT]]></title><description><![CDATA[<p dir="auto">the ignitech  has an extra wire to supply the power.</p>
]]></description><link>https://dt125r.co.uk/post/18894</link><guid isPermaLink="true">https://dt125r.co.uk/post/18894</guid><dc:creator><![CDATA[admiral323]]></dc:creator><pubDate>Sun, 06 Jan 2019 16:00:19 GMT</pubDate></item><item><title><![CDATA[Reply to wiring ignitech on Sun, 06 Jan 2019 15:47:17 GMT]]></title><description><![CDATA[<p dir="auto">Why would you wiring it to the battery directly?<br />
Wire it to the ignition switch live terminals like the original CDI.</p>
]]></description><link>https://dt125r.co.uk/post/18893</link><guid isPermaLink="true">https://dt125r.co.uk/post/18893</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 06 Jan 2019 15:47:17 GMT</pubDate></item></channel></rss>
