<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pre Mix Chart & Calculator]]></title><description><![CDATA[<p dir="auto">One of the guys shared these on the Aprilia MX group, so I thought that they might be useful to someone on here as well???</p>
<p dir="auto">Chart;</p>
<p dir="auto"><img src="https://i.imgur.com/AzNmbh3.jpg" alt="2 Stroke Premix Chart-1.jpg" class="img-markdown  img-fluid" /></p>
<p dir="auto">Or this tool calculates the quantities based on the ratio you require;</p>
<p dir="auto"><a href="http://www.premixcalculator.com/?fbclid=IwAR0Wo51Cwu4UyrQHZ2y0UmfjYGPE7oy8acxFKQ7vxf-DkJO4zbfsHuKIl2U" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.premixcalculator.com/?fbclid=IwAR0Wo51Cwu4UyrQHZ2y0UmfjYGPE7oy8acxFKQ7vxf-DkJO4zbfsHuKIl2U</a></p>
]]></description><link>https://dt125r.co.uk/topic/1816/pre-mix-chart-calculator</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 03:24:58 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1816.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Feb 2019 02:28:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pre Mix Chart & Calculator on Thu, 07 Feb 2019 20:52:46 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, most use 2% as a rule of thumb</p>
<p dir="auto">I saw a chart on the auto-pump back in the days, as I recall it pumped out 3-4% af WOT, and way less just idling or at low throttle operations. Kinda shows you the beaty of the auto-pump.</p>
<p dir="auto">Some info here: <a href="http://www.dansmc.com/2_stroke_oilpump.htm" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.dansmc.com/2_stroke_oilpump.htm</a></p>
]]></description><link>https://dt125r.co.uk/post/19458</link><guid isPermaLink="true">https://dt125r.co.uk/post/19458</guid><dc:creator><![CDATA[Jens Eskildsen]]></dc:creator><pubDate>Thu, 07 Feb 2019 20:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to Pre Mix Chart & Calculator on Thu, 07 Feb 2019 13:01:27 GMT]]></title><description><![CDATA[<p dir="auto">The basic rule for off-roaders is 2%, but as always check what your manufacturer says before listening to advice!</p>
]]></description><link>https://dt125r.co.uk/post/19448</link><guid isPermaLink="true">https://dt125r.co.uk/post/19448</guid><dc:creator><![CDATA[Minia]]></dc:creator><pubDate>Thu, 07 Feb 2019 13:01:27 GMT</pubDate></item></channel></rss>
