<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Oil from Crankcase breather and won&#x27;t rev out]]></title><description><![CDATA[<p dir="auto">Just imported 1989 dt125r. Now on the road but engine cuts out at about 8k revs. Checked YPVS valve which operated fine. Carb stripped and cleaned all good. However still won't rev out. Very occasionally it will rev almost to redline but mostly it cuts out (stutters). It's also kicking oil out of breather. Any suggestions</p>
]]></description><link>https://dt125r.co.uk/topic/1895/oil-from-crankcase-breather-and-won-t-rev-out</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 04:19:38 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1895.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Mar 2019 18:33:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Oil from Crankcase breather and won&#x27;t rev out on Sun, 31 Mar 2019 17:45:25 GMT]]></title><description><![CDATA[<p dir="auto">Reassemble is simply the reverse of the disassembly procedure.</p>
<p dir="auto">That's a gem from Haynes and about ad helpful ad an ashtray on a motorcycle ;)</p>
]]></description><link>https://dt125r.co.uk/post/20252</link><guid isPermaLink="true">https://dt125r.co.uk/post/20252</guid><dc:creator><![CDATA[Nottsbiker]]></dc:creator><pubDate>Sun, 31 Mar 2019 17:45:25 GMT</pubDate></item><item><title><![CDATA[Reply to Oil from Crankcase breather and won&#x27;t rev out on Sun, 31 Mar 2019 16:56:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: NINJA">@<bdi>NINJA</bdi></a> said in <a href="/post/20236">Oil from Crankcase breather and won't rev out</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barrelman" aria-label="Profile: Barrelman">@<bdi>Barrelman</bdi></a> Grab yourself a Haynes manual off ebay dude, there worth their weight in gold. ;)</p>
</blockquote>
<p dir="auto">Reading it as we speak</p>
]]></description><link>https://dt125r.co.uk/post/20245</link><guid isPermaLink="true">https://dt125r.co.uk/post/20245</guid><dc:creator><![CDATA[Barrelman]]></dc:creator><pubDate>Sun, 31 Mar 2019 16:56:52 GMT</pubDate></item><item><title><![CDATA[Reply to Oil from Crankcase breather and won&#x27;t rev out on Sun, 31 Mar 2019 11:33:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barrelman" aria-label="Profile: Barrelman">@<bdi>Barrelman</bdi></a> Grab yourself a Haynes manual off ebay dude, there worth their weight in gold. ;)</p>
]]></description><link>https://dt125r.co.uk/post/20236</link><guid isPermaLink="true">https://dt125r.co.uk/post/20236</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Sun, 31 Mar 2019 11:33:26 GMT</pubDate></item><item><title><![CDATA[Reply to Oil from Crankcase breather and won&#x27;t rev out on Sun, 31 Mar 2019 11:11:39 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for replies. Now to work out how to do that. Always learning</p>
]]></description><link>https://dt125r.co.uk/post/20234</link><guid isPermaLink="true">https://dt125r.co.uk/post/20234</guid><dc:creator><![CDATA[Barrelman]]></dc:creator><pubDate>Sun, 31 Mar 2019 11:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Oil from Crankcase breather and won&#x27;t rev out on Sat, 30 Mar 2019 23:15:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barrelman" aria-label="Profile: Barrelman">@<bdi>Barrelman</bdi></a> I concur with Dan. ;)</p>
]]></description><link>https://dt125r.co.uk/post/20224</link><guid isPermaLink="true">https://dt125r.co.uk/post/20224</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Sat, 30 Mar 2019 23:15:31 GMT</pubDate></item><item><title><![CDATA[Reply to Oil from Crankcase breather and won&#x27;t rev out on Sat, 30 Mar 2019 19:15:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barrelman" aria-label="Profile: Barrelman">@<bdi>Barrelman</bdi></a> said in <a href="/post/20216">Oil from Crankcase breather and won't rev out</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Bad crank seals most likely</p>
]]></description><link>https://dt125r.co.uk/post/20219</link><guid isPermaLink="true">https://dt125r.co.uk/post/20219</guid><dc:creator><![CDATA[DanRacing]]></dc:creator><pubDate>Sat, 30 Mar 2019 19:15:41 GMT</pubDate></item></channel></rss>
