<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Jetting, not the usual.]]></title><description><![CDATA[<p dir="auto">Just curious what everyone’s jetting is at, I’m on standard jets but has a different front pipe and due to the bike I cannot use an airbox.<br />
I’m thinking I need to upjet quite a bit, revs seem to hang on deceleration and there’s a fairly sizeable bog off idle, and the bike seems to have absolutely no overrun what so ever, falls on its face quite early in the Rev Range. ![0_1557003667249_614C6EE5-531F-4FCA-ABB8-017154AE16C8.png](Uploading 2%) )I’ve not even touched the carb yet to have a play with idle air mixture or needle position.</p>
<p dir="auto">Just curious as to people’s starting points really.</p>
]]></description><link>https://dt125r.co.uk/topic/1929/jetting-not-the-usual</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 19:51:43 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/1929.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 May 2019 21:01:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Jetting, not the usual. on Fri, 10 May 2019 20:05:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bodylad" aria-label="Profile: Bodylad">@<bdi>Bodylad</bdi></a> I’m running 220 main jet 27.5 pilot jet and standard needle position. This is with full dep system, v force reeds &amp; re-bored to the limit of the standard cylinder. Runs very well. Probably a tad rich. Just waiting on my zeeltronic system to arrive next.</p>
<p dir="auto">If your experiencing revs not dropping like ‘normal’, I would say your pilot jet could be either blocking up or too small.</p>
<p dir="auto">Also I tried running airbox without the snorkel but couldn’t feel any benefits when adjusted. I find the standard airbox setup perfect.</p>
<p dir="auto">Hope this helps</p>
]]></description><link>https://dt125r.co.uk/post/20633</link><guid isPermaLink="true">https://dt125r.co.uk/post/20633</guid><dc:creator><![CDATA[frazer.c]]></dc:creator><pubDate>Fri, 10 May 2019 20:05:02 GMT</pubDate></item></channel></rss>
