<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA['02 DT125R power valve]]></title><description><![CDATA[<p dir="auto">A few months ago my rear power valve cable (2) snapped. I then replaced the cable, as you do, now the servo will not line up with the hole no matter how much i adjust either cables, at the moment the rear cable is all the way out and the front is all the way in as this makes the holes line up as much as possible. However now the power valve opens at around 7k rpm when it used to open at 6k, the bike also used to get to 9k rpm red line however now i'm lucky to get it to 8k.</p>
<p dir="auto">I have searched long and hard looking for a way to fix this but haven't found anything (tried the drill bit trick and didn't work) so could anybody on here help out in any way</p>
]]></description><link>https://dt125r.co.uk/topic/2051/02-dt125r-power-valve</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 23:12:24 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2051.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Sep 2019 12:25:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to '02 DT125R power valve on Sun, 15 Sep 2019 08:56:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: NINJA">@<bdi>NINJA</bdi></a> not that I recall.</p>
]]></description><link>https://dt125r.co.uk/post/21732</link><guid isPermaLink="true">https://dt125r.co.uk/post/21732</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 15 Sep 2019 08:56:01 GMT</pubDate></item><item><title><![CDATA[Reply to '02 DT125R power valve on Sat, 14 Sep 2019 13:43:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Wasn't there a tutorial about how to set-up the PV correctly, as I can't seem to find it for some reason???</p>
]]></description><link>https://dt125r.co.uk/post/21708</link><guid isPermaLink="true">https://dt125r.co.uk/post/21708</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Sat, 14 Sep 2019 13:43:48 GMT</pubDate></item><item><title><![CDATA[Reply to '02 DT125R power valve on Sat, 14 Sep 2019 13:14:19 GMT]]></title><description><![CDATA[<p dir="auto">Try slacking both cables right off, allow the power valve motor to cycle into it's rest position and reset cables<br />
Would definitely pull out the power valve and give it all a good clean, why did the other cable fail?<br />
Also check pulley on motor isnt/hasnt slipped</p>
]]></description><link>https://dt125r.co.uk/post/21707</link><guid isPermaLink="true">https://dt125r.co.uk/post/21707</guid><dc:creator><![CDATA[oldman]]></dc:creator><pubDate>Sat, 14 Sep 2019 13:14:19 GMT</pubDate></item></channel></rss>
