<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[lights wont work]]></title><description><![CDATA[<p dir="auto">I put my dtr 125 back together. Battery showing 12.3V. My headlight is really dim. Gauge lights wont work only warning lights. Brake light works but not the rear light. Grounding issue? Fuse isnt blown.</p>
]]></description><link>https://dt125r.co.uk/topic/2129/lights-wont-work</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 12:21:00 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2129.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Feb 2020 08:55:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to lights wont work on Sun, 23 Feb 2020 09:48:08 GMT]]></title><description><![CDATA[<p dir="auto">Okay when i connect the rear light connector the lights dimm. I measured the light connector detached. Should every of 3 prongs show connected measuring with electric meter?</p>
]]></description><link>https://dt125r.co.uk/post/22536</link><guid isPermaLink="true">https://dt125r.co.uk/post/22536</guid><dc:creator><![CDATA[jonne123]]></dc:creator><pubDate>Sun, 23 Feb 2020 09:48:08 GMT</pubDate></item><item><title><![CDATA[Reply to lights wont work on Mon, 10 Feb 2020 17:39:11 GMT]]></title><description><![CDATA[<p dir="auto">But it worked before i dissasembled it. i need to check the wiring.</p>
]]></description><link>https://dt125r.co.uk/post/22434</link><guid isPermaLink="true">https://dt125r.co.uk/post/22434</guid><dc:creator><![CDATA[jonne123]]></dc:creator><pubDate>Mon, 10 Feb 2020 17:39:11 GMT</pubDate></item><item><title><![CDATA[Reply to lights wont work on Mon, 10 Feb 2020 14:12:50 GMT]]></title><description><![CDATA[<p dir="auto">Could be a dodgy voltage rectifier...</p>
]]></description><link>https://dt125r.co.uk/post/22431</link><guid isPermaLink="true">https://dt125r.co.uk/post/22431</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 10 Feb 2020 14:12:50 GMT</pubDate></item><item><title><![CDATA[Reply to lights wont work on Mon, 10 Feb 2020 10:52:16 GMT]]></title><description><![CDATA[<p dir="auto">I disconnected the tail light connector. Now everything works except temperature gauge. It shows low on when operating temperature.<br />
I can run the engine and the lights brighten when i give gas.</p>
]]></description><link>https://dt125r.co.uk/post/22429</link><guid isPermaLink="true">https://dt125r.co.uk/post/22429</guid><dc:creator><![CDATA[jonne123]]></dc:creator><pubDate>Mon, 10 Feb 2020 10:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to lights wont work on Sun, 09 Feb 2020 16:49:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonne123" aria-label="Profile: jonne123">@<bdi>jonne123</bdi></a> Are you able to run the engine, as that might change something? It will most likely be a bad ground, wrong or dodgey connection or a broken wire somewhere. Is the bulb still good too???</p>
]]></description><link>https://dt125r.co.uk/post/22422</link><guid isPermaLink="true">https://dt125r.co.uk/post/22422</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Sun, 09 Feb 2020 16:49:17 GMT</pubDate></item></channel></rss>
