<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Oil level]]></title><description><![CDATA[<p dir="auto">I have newer style clutch cover with 1 line should the oil be at that line when engine is warmed?</p>
]]></description><link>https://dt125r.co.uk/topic/2229/oil-level</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 21:52:51 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2229.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Apr 2020 19:50:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Oil level on Mon, 27 Apr 2020 18:35:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonne123" aria-label="Profile: jonne123">@<bdi>jonne123</bdi></a> as long as you put the 750 in and didn’t leak or spill any it’s fine</p>
]]></description><link>https://dt125r.co.uk/post/23269</link><guid isPermaLink="true">https://dt125r.co.uk/post/23269</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Mon, 27 Apr 2020 18:35:15 GMT</pubDate></item><item><title><![CDATA[Reply to Oil level on Mon, 27 Apr 2020 18:01:37 GMT]]></title><description><![CDATA[<p dir="auto">It looks low after i added the oil</p>
]]></description><link>https://dt125r.co.uk/post/23266</link><guid isPermaLink="true">https://dt125r.co.uk/post/23266</guid><dc:creator><![CDATA[jonne123]]></dc:creator><pubDate>Mon, 27 Apr 2020 18:01:37 GMT</pubDate></item><item><title><![CDATA[Reply to Oil level on Sun, 26 Apr 2020 20:33:31 GMT]]></title><description><![CDATA[<p dir="auto">750ml of oil. It says it on the side of the case.</p>
]]></description><link>https://dt125r.co.uk/post/23244</link><guid isPermaLink="true">https://dt125r.co.uk/post/23244</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 26 Apr 2020 20:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to Oil level on Sun, 26 Apr 2020 20:09:22 GMT]]></title><description><![CDATA[<p dir="auto">In haynes manual it says run it wait the oill to setle</p>
]]></description><link>https://dt125r.co.uk/post/23242</link><guid isPermaLink="true">https://dt125r.co.uk/post/23242</guid><dc:creator><![CDATA[jonne123]]></dc:creator><pubDate>Sun, 26 Apr 2020 20:09:22 GMT</pubDate></item><item><title><![CDATA[Reply to Oil level on Sun, 26 Apr 2020 19:55:08 GMT]]></title><description><![CDATA[<p dir="auto">you always check/set oil levels when cold</p>
]]></description><link>https://dt125r.co.uk/post/23241</link><guid isPermaLink="true">https://dt125r.co.uk/post/23241</guid><dc:creator><![CDATA[tunertom]]></dc:creator><pubDate>Sun, 26 Apr 2020 19:55:08 GMT</pubDate></item></channel></rss>
