<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[3BN 3pin YPVS Conversion]]></title><description><![CDATA[<p dir="auto">Has anyone had any experience or knowledge of retrofitting a 3pin YPVS to a ‘fixed’ PV on a 3bn engine?<br />
I’m guessing that it uses the blank 2pin plug and single wire (from CDI unit) and opens according to the revs that the CDI is ‘sending’...<br />
Does it use the standard valve or is the Powered one different?</p>
]]></description><link>https://dt125r.co.uk/topic/2248/3bn-3pin-ypvs-conversion</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 04:52:35 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2248.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 May 2020 12:52:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 3BN 3pin YPVS Conversion on Sat, 16 May 2020 19:26:02 GMT]]></title><description><![CDATA[<p dir="auto">As far as I am aware only one drive pulley, all mine early models.</p>
]]></description><link>https://dt125r.co.uk/post/23500</link><guid isPermaLink="true">https://dt125r.co.uk/post/23500</guid><dc:creator><![CDATA[oldman]]></dc:creator><pubDate>Sat, 16 May 2020 19:26:02 GMT</pubDate></item><item><title><![CDATA[Reply to 3BN 3pin YPVS Conversion on Sat, 16 May 2020 12:47:30 GMT]]></title><description><![CDATA[<p dir="auto">Nah the 5 wire one uses a different CDI and loom. It was the bobbin I was wondering about</p>
]]></description><link>https://dt125r.co.uk/post/23499</link><guid isPermaLink="true">https://dt125r.co.uk/post/23499</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Sat, 16 May 2020 12:47:30 GMT</pubDate></item><item><title><![CDATA[Reply to 3BN 3pin YPVS Conversion on Fri, 15 May 2020 13:43:52 GMT]]></title><description><![CDATA[<p dir="auto">Do you mean is the YPVS bobbin in the cylinder different?</p>
<p dir="auto">There are 2 types of valve from memory, one with a diamond shape on the end and one with a rectangular shape - I think that they use the same cable holder but I'm not 100% on this</p>
<p dir="auto">My TDR125 came without a servo motor so I bought a 3 wire one and it looks like it will fit straight on. Not sure if the later 5 wire one can be adapted to fit either if thats what you were kind of asking</p>
]]></description><link>https://dt125r.co.uk/post/23490</link><guid isPermaLink="true">https://dt125r.co.uk/post/23490</guid><dc:creator><![CDATA[Nottsbiker]]></dc:creator><pubDate>Fri, 15 May 2020 13:43:52 GMT</pubDate></item></channel></rss>
