<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Advice removing oil delivery hose]]></title><description><![CDATA[<p dir="auto">Hi, just looking to replace my DT125 98' with Clear Oil delivery hose from Yambits, looking at the original Yamaha hose clips at both ends (Oil Pump &amp; Delivery) they appear to need to be forced open with a small screw driver as they don't have any obvious way to loosen.</p>
<p dir="auto">Has anyone else manage to remove the original oil clips? if so i'd appreciate if there was a good method you used without damaging the original parts.</p>
<p dir="auto"><img src="/assets/uploads/files/1590496141176-capture1.png" alt="Capture1.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1590496182039-capture2.png" alt="Capture2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://dt125r.co.uk/topic/2265/advice-removing-oil-delivery-hose</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 12:36:42 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2265.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 May 2020 12:27:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Advice removing oil delivery hose on Tue, 26 May 2020 12:57:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Amazing thank you, i'll give it a try now <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://dt125r.co.uk/post/23577</link><guid isPermaLink="true">https://dt125r.co.uk/post/23577</guid><dc:creator><![CDATA[rollzy101]]></dc:creator><pubDate>Tue, 26 May 2020 12:57:38 GMT</pubDate></item><item><title><![CDATA[Reply to Advice removing oil delivery hose on Tue, 26 May 2020 12:46:30 GMT]]></title><description><![CDATA[<p dir="auto">They don't need to be forced open. They have a small slit in them, so they will come off if you're gentle.</p>
]]></description><link>https://dt125r.co.uk/post/23574</link><guid isPermaLink="true">https://dt125r.co.uk/post/23574</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 26 May 2020 12:46:30 GMT</pubDate></item></channel></rss>
