<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dt 125re No power.]]></title><description><![CDATA[<p dir="auto">Hi everyone I am Andrew and I have a dt 125 re 2005 which feels really flat. I have just put a new piston and rings in, done the crank seals etc. It ticks over smooth and drives through all the gears but is really lagging in power in ever gear. I have pinned the power valve open half way to try that but it is still flat. You open it up we're it starts to get going but just bottoms out on the revs change gear bottoms out again. When you put full throttle out and max it to the top it starts to miss like it's not sparking right or not getting enough fuel to give it that extra power. does not have that power valve type feeling on it. I can ride it about round the doors but it is so flat. Only Doing about 40 mph top end.</p>
]]></description><link>https://dt125r.co.uk/topic/2308/dt-125re-no-power</link><generator>RSS for Node</generator><lastBuildDate>Sun, 06 Sep 2026 12:00:40 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2308.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Jun 2020 22:25:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dt 125re No power. on Sat, 04 Jul 2020 01:26:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/baileyboy2008" aria-label="Profile: Baileyboy2008">@<bdi>Baileyboy2008</bdi></a> well like Calum pointed out there’s no such thing as pinning your valve half way if the valve is have way closed you will get zero power above 6k open her all the way and then see what it does</p>
]]></description><link>https://dt125r.co.uk/post/24083</link><guid isPermaLink="true">https://dt125r.co.uk/post/24083</guid><dc:creator><![CDATA[declan]]></dc:creator><pubDate>Sat, 04 Jul 2020 01:26:14 GMT</pubDate></item><item><title><![CDATA[Reply to Dt 125re No power. on Sat, 04 Jul 2020 01:12:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> done a compression test and only getting 90psi on the gauge. I had 90psi on the other head before changing it. Either my gauge is wrong or I have done something wrong with the rings or something. Any suggestions to check it all.</p>
]]></description><link>https://dt125r.co.uk/post/24082</link><guid isPermaLink="true">https://dt125r.co.uk/post/24082</guid><dc:creator><![CDATA[Baileyboy2008]]></dc:creator><pubDate>Sat, 04 Jul 2020 01:12:15 GMT</pubDate></item><item><title><![CDATA[Reply to Dt 125re No power. on Tue, 30 Jun 2020 04:23:33 GMT]]></title><description><![CDATA[<p dir="auto">Pinning the valve half way isn't pinning the valve.</p>
<p dir="auto">But it'll most likely be restricted.</p>
<p dir="auto">Perform the derestricted mod, with the first one being the green and black wire behind the clocks, and the bike should whizz through the gears and pull hard to around 12k. Note in this instance the valve should be fully operational.</p>
]]></description><link>https://dt125r.co.uk/post/23992</link><guid isPermaLink="true">https://dt125r.co.uk/post/23992</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 30 Jun 2020 04:23:33 GMT</pubDate></item></channel></rss>
