<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DT125R fuel out of the overflow]]></title><description><![CDATA[<p dir="auto">Hi, just fired up my DT after a couple of weeks non-use, filled it up from a fuel container at home and after filling about 3/4 up to the tank, turned on the fuel stop-cock/switch and quite a bit of fuel poured out of the overflow. Stopped when ever I turned off the fuel. Eventually it did stop coming out, probably down lost a couple of litres. Fired up no problem and no other issues.</p>
<p dir="auto">Anyone know if it sounds like the sheer volume of fuel is forcing itself past some worn carb bits?</p>
<p dir="auto">Once had the opposite of this on an old BMW diesel car, when one of the 2 pumps stopped working, if you kept it topped up enough would have a problem, due to 'weight' of fuel.</p>
<p dir="auto">Thanks, Mark</p>
]]></description><link>https://dt125r.co.uk/topic/2386/dt125r-fuel-out-of-the-overflow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 22:53:23 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2386.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Sep 2020 18:06:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DT125R fuel out of the overflow on Mon, 28 Sep 2020 19:09:23 GMT]]></title><description><![CDATA[<p dir="auto">I’ve had similar temperamental problems with this (&amp; a 100 other things!!)<br />
The only thing it can be is the needle valve that is operated by the floats (or the floats themselves!)old fuel varnish or dirt is the usual suspect...<br />
You can get a replacement kit I think. The needle and the brass insert it fits into...<br />
A good inspection and clean is usually good enough...<br />
P.S. the ‘weight’ of fuel can exasperate the situation, or it has in my experience (which isn’t much!)...</p>
]]></description><link>https://dt125r.co.uk/post/24799</link><guid isPermaLink="true">https://dt125r.co.uk/post/24799</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Mon, 28 Sep 2020 19:09:23 GMT</pubDate></item><item><title><![CDATA[Reply to DT125R fuel out of the overflow on Mon, 28 Sep 2020 16:45:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gibboharps" aria-label="Profile: gibboharps">@<bdi>gibboharps</bdi></a> had a similar issue before, went out side one night to find I’d lost half a tank of fuel. For about a week on and off the carb would leak out the overflow until one night I thrashed it a bit more then I should’ve only for it to fix itself.</p>
<p dir="auto">I figured a bit of shit fuel got stuck or dirt stopped the thing from seating properly</p>
]]></description><link>https://dt125r.co.uk/post/24791</link><guid isPermaLink="true">https://dt125r.co.uk/post/24791</guid><dc:creator><![CDATA[Stevie Wonder]]></dc:creator><pubDate>Mon, 28 Sep 2020 16:45:01 GMT</pubDate></item><item><title><![CDATA[Reply to DT125R fuel out of the overflow on Sun, 27 Sep 2020 18:42:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Thanks Calum - will give this a go, prob a one-off <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://dt125r.co.uk/post/24786</link><guid isPermaLink="true">https://dt125r.co.uk/post/24786</guid><dc:creator><![CDATA[gibboharps]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:42:04 GMT</pubDate></item><item><title><![CDATA[Reply to DT125R fuel out of the overflow on Sun, 27 Sep 2020 18:18:31 GMT]]></title><description><![CDATA[<p dir="auto">I never got this on my Mikuni, but I swapped it out for a Dellorto VHSA 32mm found on the TZR RR Belgards and got the same issues.</p>
<p dir="auto">I always found, quick blip up the road and it sorts itself out.</p>
]]></description><link>https://dt125r.co.uk/post/24785</link><guid isPermaLink="true">https://dt125r.co.uk/post/24785</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:18:31 GMT</pubDate></item></channel></rss>
