<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Titanium Front Engine Mount Bolt]]></title><description><![CDATA[<p dir="auto">So I've got the engine out to try and sort the oil leak, thought I'd do all the bolts for some titanium.</p>
<p dir="auto">Whilst looking I see that someone on eBay sells the right bolt for the front engine mount.</p>
<p dir="auto"><a href="https://www.ebay.co.uk/itm/Suzuki-TITANIUM-M10x125mm-bolt-and-nut-Totally-stainless-Half-the-weight/263041579386?ssPageName=STRK%3AMEBIDX%3AIT&amp;var=562045001191&amp;_trksid=p2060353.m2749.l2649" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ebay.co.uk/itm/Suzuki-TITANIUM-M10x125mm-bolt-and-nut-Totally-stainless-Half-the-weight/263041579386?ssPageName=STRK%3AMEBIDX%3AIT&amp;var=562045001191&amp;_trksid=p2060353.m2749.l2649</a></p>
<p dir="auto"><img src="https://i.ebayimg.com/images/g/1mwAAOSwBLlU22yB/s-l1600.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">M10x125mm</p>
<p dir="auto">Thought worth mentioning that this fits our DTRs too so if you wanted to replace some of the bigger bolts with something lighter...there you go.</p>
]]></description><link>https://dt125r.co.uk/topic/2464/titanium-front-engine-mount-bolt</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 23:04:59 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2464.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Oct 2020 10:35:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Titanium Front Engine Mount Bolt on Wed, 28 Oct 2020 19:19:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/llldennis" aria-label="Profile: lllDennis">@<bdi>lllDennis</bdi></a> So my rebuild consisted of Stainless as it's cheap.</p>
<p dir="auto">I just got all the bolts for the engine from "Raceti" and that cost me £145. So it's not cheap. And I'm sure you can appreciate there are a lot more bolts than just the engine.</p>
<p dir="auto">The thing that hurts is when they rattle off! <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f923.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--rolling_on_the_floor_laughing" style="height:23px;width:auto;vertical-align:middle" title=":rolling_on_the_floor_laughing:" alt="🤣" /></p>
]]></description><link>https://dt125r.co.uk/post/25192</link><guid isPermaLink="true">https://dt125r.co.uk/post/25192</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 28 Oct 2020 19:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to Titanium Front Engine Mount Bolt on Wed, 28 Oct 2020 19:11:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> It's worth a shot. Don't see a reason that it wouldn't fit.<br />
I was actually making a list to order a full Inox A2 bolts and nuts. To prevent any rust. But actually the titanium makes a lot more sense <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44c.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--ok_hand" style="height:23px;width:auto;vertical-align:middle" title="👌" alt="👌" /></p>
]]></description><link>https://dt125r.co.uk/post/25190</link><guid isPermaLink="true">https://dt125r.co.uk/post/25190</guid><dc:creator><![CDATA[lllDennis]]></dc:creator><pubDate>Wed, 28 Oct 2020 19:11:36 GMT</pubDate></item><item><title><![CDATA[Reply to Titanium Front Engine Mount Bolt on Wed, 28 Oct 2020 18:44:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/llldennis" aria-label="Profile: lllDennis">@<bdi>lllDennis</bdi></a> I haven't checked to make sure it actually slides through the engine, but I see no reason why not.</p>
<p dir="auto">So unlike Stainless Steel bolts, this is designed to be under tension. Up to 64nm, which should be plenty for the front engine mount. There is a noticeable difference between this and the stock bolt. That doesn't mean much on its own, but couple it with a whole array of bolts and you will shave off plenty of weight.</p>
<p dir="auto">I also did the rear engine mount, but that was a much more accessible M8 60mm so nothing to write home about. And was like £5. But the M10 is a little hard to get ahold of.</p>
]]></description><link>https://dt125r.co.uk/post/25188</link><guid isPermaLink="true">https://dt125r.co.uk/post/25188</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 28 Oct 2020 18:44:47 GMT</pubDate></item><item><title><![CDATA[Reply to Titanium Front Engine Mount Bolt on Wed, 28 Oct 2020 18:14:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> Looks really Nice. Tempted to order <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title="😁" alt="😁" /></p>
]]></description><link>https://dt125r.co.uk/post/25187</link><guid isPermaLink="true">https://dt125r.co.uk/post/25187</guid><dc:creator><![CDATA[lllDennis]]></dc:creator><pubDate>Wed, 28 Oct 2020 18:14:13 GMT</pubDate></item></channel></rss>
