<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Air box design questions]]></title><description><![CDATA[<p dir="auto">Hi all -</p>
<p dir="auto">I am having a discussion with a friend on another forum regarding snorkels &amp; air boxes, he states that the air box 2T design, is a reservoir and the carb needs a still vacuum of air to suck from. Has anyone any knowledge of this and can confirm or disprove this theory please?</p>
<p dir="auto">His words;</p>
<p dir="auto">"I think we do not actually want to direct air to the pipercross air filter...my (limited) understanding is that the 2 stroke air box is more of a reservoir of calm air...unlike a car where we want to direct cold air at the carb. The 2 stroke design is normally to allow the air to settle before the carb sucks it in and also there is a pulse wave (I think) as this acts like a supercharger effect when the pulse moves through the exhaust. I am only guessing but the snorkel needs to be very short inside the air box to allow the air to settle first?"</p>
<p dir="auto">TIA</p>
]]></description><link>https://dt125r.co.uk/topic/2561/air-box-design-questions</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 20:09:15 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2561.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Feb 2021 13:03:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Air box design questions on Thu, 18 Feb 2021 14:15:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dtr-nsr" aria-label="Profile: dtr-nsr">@<bdi>dtr-nsr</bdi></a> Thanks for the input guys. It's a very interesting topic, which will have many viewpoints and will surely be a hot debatable one for many years to come!!! <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title="😉" alt="😉" /></p>
]]></description><link>https://dt125r.co.uk/post/25928</link><guid isPermaLink="true">https://dt125r.co.uk/post/25928</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Thu, 18 Feb 2021 14:15:03 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Thu, 18 Feb 2021 12:01:50 GMT]]></title><description><![CDATA[<p dir="auto">Ninja's friend is very much right, typically the bigger the air box the better. But a manufacturer can tweak the volume of the air box, to change its resonance, to help fill a flat spot in the rpm range. To make a engine more flexible, not something that important on a engine that will be running a full tilt most the time.</p>
<p dir="auto">Most 'ram air' intakes are just cold air feeds, I believe the Yamaha thundercat was one of the first bikes to run a true ram air setup. And that is far more than just sealed air feeds to the airbox. It has various air chambers under the fairings, and even uses the air to pressurise the float bowls on the carbs to increase fueling to match. And with all that, it's claimed to only add 3hp at over 100mph, and that's on a near 100bhp engine.</p>
<p dir="auto">Unless your trying to chase every last 0.5hp, I think your best off with a air box, especially on the street.</p>
]]></description><link>https://dt125r.co.uk/post/25927</link><guid isPermaLink="true">https://dt125r.co.uk/post/25927</guid><dc:creator><![CDATA[DTR+NSR]]></dc:creator><pubDate>Thu, 18 Feb 2021 12:01:50 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Wed, 17 Feb 2021 18:36:00 GMT]]></title><description><![CDATA[<p dir="auto">The only thing I know for sure is that the air box is a giant pain in the ass to fit and remove. If I was working regularly on the engine I’d use a pod...</p>
]]></description><link>https://dt125r.co.uk/post/25926</link><guid isPermaLink="true">https://dt125r.co.uk/post/25926</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Wed, 17 Feb 2021 18:36:00 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Thu, 18 Feb 2021 13:51:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> It's all very interesting stuff for-sure, thermo-dynamics obviously play a big part in performance. Along with air quality, density and temperatures as well. My friend posted this reply which is all very interesting;</p>
<p dir="auto">"I do believe that air box volume in the still air portion is important to lessen engine acceleration issues from inadequate immediate airflow across the filter. Books written on the subject indicate suggested air box volumes needed.<br />
Resonant tuning a two stroke, and even the four strokes brings the discussion of fuel stand off in the carb air inlet bell and extending even some short distance up the air boot. Fuel stand off is a function of resonance. The engine pulses generate a reverse wave through the carb and since not all fuel is consumed on each intake function, the resonant wave tends to carry atomized fuel back to the waves break point. The break point is a function of throttle opening, engine intake timing, and the mass of the air being moved.</p>
<p dir="auto">On a steady throttle operation, such as the examples posted earlier, a known setup can be made and tested to optimize resonance and fuel stand off. At low throttle settings, and changing throttle settings, resonance seems less important.</p>
<p dir="auto">I do consider the rubber air boot between the carb inlet airbell and the air box important. Not in a sense to gain a resonance performance gain, but rather to minimize premix spray into the still air box."</p>
]]></description><link>https://dt125r.co.uk/post/25919</link><guid isPermaLink="true">https://dt125r.co.uk/post/25919</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Thu, 18 Feb 2021 13:51:45 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 20:02:21 GMT]]></title><description><![CDATA[<p dir="auto">I'm not terribly convinced. I long ago ditched the airbox on my bikes, My RS is fairly rapid.</p>
<p dir="auto">Airbox is good on MX to avoid getting dirt/grit into/near the filter.</p>
<p dir="auto">For a road going daily it makes sense to avoid the filter getting wet on your daily commute.</p>
<p dir="auto">But it terms of real world performance? I doubt it's much if any. In fact, probably better gains to be had binning the airbox in favour for a pod filter just in terms of weight savings alone <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f923.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--rolling_on_the_floor_laughing" style="height:23px;width:auto;vertical-align:middle" title=":rolling_on_the_floor_laughing:" alt="🤣" /></p>
<p dir="auto">I have no facts to base this on. For me it just comes down to if I really wanted more power. go bigger on displacement.</p>
<p dir="auto">For me it's just a convenience factor. It's easier to service and rejet on a pod filter when compared to an airbox. It also allows easier access to the important things when it comes to servicing too.</p>
<p dir="auto">The portgual lot aren't bothered with airboxes and their bikes are far faster than ours.</p>
<p dir="auto"><img src="https://i.ytimg.com/vi/5qPn8wcN6Go/maxresdefault.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">My guess is that due to their better climate, they don't have to put up with the crappy weather we get here.</p>
<p dir="auto">BARacing</p>
<p dir="auto"><img src="https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/p960x960/72059824_1413329305512318_9070861270046998528_o.jpg?_nc_cat=103&amp;ccb=3&amp;_nc_sid=110474&amp;_nc_ohc=XF0M1AvAnR8AX-NO8PY&amp;_nc_ht=scontent-lht6-1.xx&amp;tp=6&amp;oh=cfa1522f1a4c482609900eae00ade5d7&amp;oe=60524F56" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/post/25918</link><guid isPermaLink="true">https://dt125r.co.uk/post/25918</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 16 Feb 2021 20:02:21 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 19:34:58 GMT]]></title><description><![CDATA[<p dir="auto">Cut the lid off and send it</p>
]]></description><link>https://dt125r.co.uk/post/25917</link><guid isPermaLink="true">https://dt125r.co.uk/post/25917</guid><dc:creator><![CDATA[Glynn123]]></dc:creator><pubDate>Tue, 16 Feb 2021 19:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 19:31:55 GMT]]></title><description><![CDATA[<p dir="auto">AAAHHH!! So I'm guessing that the snorkel acts as a funnel to push air into the box, which creates a sort of vacuum for air to be rammed in at a higher velocity then? With the actual air box acting as a reservoir, or volume of air for the carb to suck air in from? Does that about sum it up?</p>
<p dir="auto">And does this make the air more denser or not then? Or is air just plain ole air??? <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f600.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--grinning" style="height:23px;width:auto;vertical-align:middle" title=":grinning:" alt="😀" /> <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /> <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60b.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--yum" style="height:23px;width:auto;vertical-align:middle" title=":yum:" alt="😋" /></p>
<p dir="auto">I found this really interesting thread for more info;</p>
<p dir="auto"><a href="https://www.125ccsportsbikes.com/forums/index.php?showtopic=104889" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.125ccsportsbikes.com/forums/index.php?showtopic=104889</a></p>
]]></description><link>https://dt125r.co.uk/post/25916</link><guid isPermaLink="true">https://dt125r.co.uk/post/25916</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Tue, 16 Feb 2021 19:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 19:13:28 GMT]]></title><description><![CDATA[<p dir="auto">Something I learned from her and then from a couple of the 2t R&amp;D groups</p>
<p dir="auto">Velocity and Density.<br />
Your air box is more then a reservoir, if you want an example of that then look at what the YIES does.<br />
Imagine your air box not as an active space doing stuff but a channel between the areas that make a difference to the stuff that’s happening.</p>
<p dir="auto">I feel like I can kinda get where your friend is coming from on the idea that you need to have a consistent air flow or a “settled air” but the principles with air and engines seem pretty universal regardless of what it is</p>
]]></description><link>https://dt125r.co.uk/post/25915</link><guid isPermaLink="true">https://dt125r.co.uk/post/25915</guid><dc:creator><![CDATA[Stevie Wonder]]></dc:creator><pubDate>Tue, 16 Feb 2021 19:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 18:09:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: spookdog">@<bdi>spookdog</bdi></a> The RS 125 was raced competitively alongside the Honda RS125 in the Superteen GP Series.</p>
<p dir="auto">So disregard the fact it was a learner legal 125, these things were well spec'd.</p>
]]></description><link>https://dt125r.co.uk/post/25912</link><guid isPermaLink="true">https://dt125r.co.uk/post/25912</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 16 Feb 2021 18:09:51 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 16:55:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: ninja">@<bdi>ninja</bdi></a><br />
I don’t know enough to form an opinion, but I’d look towards the design on bikes like YZ Rm’s, ect. Bikes that are fully tuned with no eye towards restriction. They probably chucked about as many Yen as possible into R&amp;D <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title="🙂" alt="🙂" /></p>
]]></description><link>https://dt125r.co.uk/post/25910</link><guid isPermaLink="true">https://dt125r.co.uk/post/25910</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Tue, 16 Feb 2021 16:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 16:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninja" aria-label="Profile: ninja">@<bdi>ninja</bdi></a> Well, yes, see where the frame is. There are two plastic snorkels that stick out. Actually these fit into the nose cone. The air is channelled through the frame to the Air box snorkel.</p>
]]></description><link>https://dt125r.co.uk/post/25908</link><guid isPermaLink="true">https://dt125r.co.uk/post/25908</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 16 Feb 2021 16:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 15:43:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: calum">@<bdi>calum</bdi></a> Thanks-  How are they actually ramming the air in please? As its a bit difficult to spot in that pic.</p>
]]></description><link>https://dt125r.co.uk/post/25907</link><guid isPermaLink="true">https://dt125r.co.uk/post/25907</guid><dc:creator><![CDATA[NINJA]]></dc:creator><pubDate>Tue, 16 Feb 2021 15:43:33 GMT</pubDate></item><item><title><![CDATA[Reply to Air box design questions on Tue, 16 Feb 2021 14:18:42 GMT]]></title><description><![CDATA[<p dir="auto">Aprilia RS125 used RAM Air Technology to force feed cool air into the air box.</p>
<p dir="auto"><img src="https://www.motorcyclespecs.co.za/Gallery/Aprilia-RS125-94-01.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Aprilia aren't thick, they know what they're doing.</p>
]]></description><link>https://dt125r.co.uk/post/25906</link><guid isPermaLink="true">https://dt125r.co.uk/post/25906</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 16 Feb 2021 14:18:42 GMT</pubDate></item></channel></rss>
