<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Jetting Athena 170kit dtr]]></title><description><![CDATA[<p dir="auto">What jetting do you recommend on a Yamaha dtr 2003 model with Athena exhaust and stock mikuni carb. And 170 Athena big bore kit</p>
]]></description><link>https://dt125r.co.uk/topic/2582/jetting-athena-170kit-dtr</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 23:05:43 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2582.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Mar 2021 20:39:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Jetting Athena 170kit dtr on Sun, 11 Apr 2021 06:19:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/waale2004" aria-label="Profile: waale2004">@<bdi>waale2004</bdi></a>  Best jetting for Athena 170 is 300 main jet on the<br />
Mikuni tm28 but with the powerjet blocked off. Just cut the<br />
rubber tube in half from the float chamber to the powerjet then block the 2 halves of the rubber tube with a couple of 5mm threaded bolts or similar.</p>
]]></description><link>https://dt125r.co.uk/post/26258</link><guid isPermaLink="true">https://dt125r.co.uk/post/26258</guid><dc:creator><![CDATA[theportingmaster]]></dc:creator><pubDate>Sun, 11 Apr 2021 06:19:11 GMT</pubDate></item></channel></rss>
