<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do you wire a stator&#x2F;magneto?]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’ve identified my stator/magneto as dead. I’ve sourced a replacement unit, which has been removed from a working engine, however when it arrived the wiring is cut from the block connector.</p>
<p dir="auto">I’ve still got the original so am familiar where the wires need to go, however three of them are solid white, so could they go to any of the three pins?</p>
<p dir="auto">Thanks in advance,</p>
<p dir="auto">Tom!</p>
]]></description><link>https://dt125r.co.uk/topic/2636/how-do-you-wire-a-stator-magneto</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 13:02:01 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2636.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 May 2021 21:49:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do you wire a stator&#x2F;magneto? on Thu, 03 Jun 2021 23:57:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: spookdog">@<bdi>spookdog</bdi></a> Hi mate, the wiring is currently stripped right back on the replacement unit. I think I may have it sorta resolved now, gonna fit it tomorrow and see if it runs!</p>
]]></description><link>https://dt125r.co.uk/post/26498</link><guid isPermaLink="true">https://dt125r.co.uk/post/26498</guid><dc:creator><![CDATA[GoProKid95]]></dc:creator><pubDate>Thu, 03 Jun 2021 23:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to How do you wire a stator&#x2F;magneto? on Tue, 01 Jun 2021 05:37:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goprokid95" aria-label="Profile: goprokid95">@<bdi>goprokid95</bdi></a><br />
Can you not jus trace them back on the original? Remove and replace the outer sleeve if needed...</p>
]]></description><link>https://dt125r.co.uk/post/26458</link><guid isPermaLink="true">https://dt125r.co.uk/post/26458</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Tue, 01 Jun 2021 05:37:52 GMT</pubDate></item></channel></rss>
