<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Solenoid relays under seat?]]></title><description><![CDATA[<p dir="auto">There are 2 of them and I still haven’t found a satisfactory answer as to what they are or do. The nearest my searching has found is 1 is a <em>neutral relay</em> but that doesn’t make any sense to me. I thought 1 might be to do with the side stand kill switch function. The other one would still be a mystery if I’m right about the sidestand.<br />
It’s an early 1988~96 loom and magneto. Any light shed would be appreciated.<br />
P.S. I <strong>have</strong> tried the search function <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f925.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--lying_face" style="height:23px;width:auto;vertical-align:middle" title="🤥" alt="🤥" /></p>
<p dir="auto">Thank yoos’</p>
]]></description><link>https://dt125r.co.uk/topic/2646/solenoid-relays-under-seat</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 14:16:16 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2646.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Jun 2021 21:48:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Solenoid relays under seat? on Sun, 13 Jun 2021 13:46:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan28" aria-label="Profile: dan28">@<bdi>dan28</bdi></a><br />
I don’t have a electric start. I have an 88 DTR125  Also my indicator relay is a 3 pin one behind the headlight. These 2 are 4pin. They control the sidestand kill switch, which the previous owner removed from my bike <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f644.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--face_with_rolling_eyes" style="height:23px;width:auto;vertical-align:middle" title="🙄" alt="🙄" /></p>
<p dir="auto">PS modern bikes are a bit more solid state,...</p>
<p dir="auto">I know it doesn’t sound right, and might not be as I stated it. I am sure that it is to stop you pulling away with the side stand down. 1 neutral switch, 1 relay. 1 sidestand switch 1 relay. It’s how old computers worked before solid state. On a newer bike the ecu would probably do the job...</p>
]]></description><link>https://dt125r.co.uk/post/26600</link><guid isPermaLink="true">https://dt125r.co.uk/post/26600</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Sun, 13 Jun 2021 13:46:56 GMT</pubDate></item><item><title><![CDATA[Reply to Solenoid relays under seat? on Sun, 13 Jun 2021 13:03:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: spookdog">@<bdi>spookdog</bdi></a> it doesn't sound right to me as all bikes would have them<br />
It's more likely one is relay for electric start an the other is flasher relay</p>
]]></description><link>https://dt125r.co.uk/post/26599</link><guid isPermaLink="true">https://dt125r.co.uk/post/26599</guid><dc:creator><![CDATA[dan28]]></dc:creator><pubDate>Sun, 13 Jun 2021 13:03:56 GMT</pubDate></item><item><title><![CDATA[Reply to Solenoid relays under seat? on Sat, 12 Jun 2021 00:49:38 GMT]]></title><description><![CDATA[<p dir="auto">@markus-w<br />
Cheers bud!...</p>
]]></description><link>https://dt125r.co.uk/post/26592</link><guid isPermaLink="true">https://dt125r.co.uk/post/26592</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Sat, 12 Jun 2021 00:49:38 GMT</pubDate></item><item><title><![CDATA[Reply to Solenoid relays under seat? on Fri, 11 Jun 2021 21:06:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: spookdog">@<bdi>spookdog</bdi></a> xt350, goes up to 110mph and is same shape and size. Also same size front wheel but I'm not sure maybe you would need the Speedo drive too.</p>
]]></description><link>https://dt125r.co.uk/post/26589</link><guid isPermaLink="true">https://dt125r.co.uk/post/26589</guid><dc:creator><![CDATA[markus.w]]></dc:creator><pubDate>Fri, 11 Jun 2021 21:06:13 GMT</pubDate></item><item><title><![CDATA[Reply to Solenoid relays under seat? on Fri, 11 Jun 2021 19:16:31 GMT]]></title><description><![CDATA[<p dir="auto">Another question!</p>
<p dir="auto">Are there any speedometers, of my size and shape, that go over 80MPH?<br />
<img src="https://i.imgur.com/3OSuTM0.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/post/26587</link><guid isPermaLink="true">https://dt125r.co.uk/post/26587</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Fri, 11 Jun 2021 19:16:31 GMT</pubDate></item><item><title><![CDATA[Reply to Solenoid relays under seat? on Thu, 10 Jun 2021 17:34:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nottsbiker" aria-label="Profile: nottsbiker">@<bdi>nottsbiker</bdi></a><br />
I think I’ve sussed it. Relay 1 is to ‘tell’ the circuit that it’s out of neutral (and so activate relay 2). 2 is to ‘tell’ the circuit that the stand is up and safe to run. If the stand is down it will earth/kill the ignition!<br />
That took me some thinking!! <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f633.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--flushed" style="height:23px;width:auto;vertical-align:middle" title="😳" alt="😳" /></p>
]]></description><link>https://dt125r.co.uk/post/26579</link><guid isPermaLink="true">https://dt125r.co.uk/post/26579</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Thu, 10 Jun 2021 17:34:26 GMT</pubDate></item><item><title><![CDATA[Reply to Solenoid relays under seat? on Thu, 10 Jun 2021 08:34:13 GMT]]></title><description><![CDATA[<p dir="auto">In my 3SH TDR parts catalogue they are listed as "relay assembly" with no other details</p>
<p dir="auto">Usually relays are for the starter motor, headlights, side-stand etc so I think that you are quite close</p>
]]></description><link>https://dt125r.co.uk/post/26570</link><guid isPermaLink="true">https://dt125r.co.uk/post/26570</guid><dc:creator><![CDATA[Nottsbiker]]></dc:creator><pubDate>Thu, 10 Jun 2021 08:34:13 GMT</pubDate></item><item><title><![CDATA[Reply to Solenoid relays under seat? on Wed, 09 Jun 2021 22:03:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: spookdog">@<bdi>spookdog</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/scrimsmustang" aria-label="Profile: scrimsmustang">@<bdi>scrimsmustang</bdi></a>  Would know what they are. Especially if you find it on Fowlers and get the part number.</p>
]]></description><link>https://dt125r.co.uk/post/26569</link><guid isPermaLink="true">https://dt125r.co.uk/post/26569</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Wed, 09 Jun 2021 22:03:16 GMT</pubDate></item></channel></rss>
