<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dt 125 Brake Caliper Upgrade Plug and Play]]></title><description><![CDATA[<p dir="auto">Hello, I am Vito from munich. I rebuild my Dt 125 r from 2001 last winter. I am very happy with the whole bike but i am very unsatisfied with the stock braking power. Is there a possibility to mount a brake caliper that fits P&amp;P? Thank you very much in fellows. Kind regards Vito</p>
]]></description><link>https://dt125r.co.uk/topic/2728/dt-125-brake-caliper-upgrade-plug-and-play</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 20:00:05 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2728.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Sep 2021 13:12:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dt 125 Brake Caliper Upgrade Plug and Play on Tue, 28 Sep 2021 11:12:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vitoast" aria-label="Profile: vitoast">@<bdi>vitoast</bdi></a> said in <a href="/post/27154">Dt 125 Brake Caliper Upgrade Plug and Play</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Later Re models run nissin rear brake callipers, that’s plug in and play but the brand name is the only difference you’ll see as they’re both single piston callipers that use identical pads.</p>
<p dir="auto">Also for less effort and cost you could buy a front end of WR125X. 320mm disc, 17” sumo wheels and lots of brembo upgrades</p>
]]></description><link>https://dt125r.co.uk/post/27157</link><guid isPermaLink="true">https://dt125r.co.uk/post/27157</guid><dc:creator><![CDATA[Stevie Wonder]]></dc:creator><pubDate>Tue, 28 Sep 2021 11:12:05 GMT</pubDate></item><item><title><![CDATA[Reply to Dt 125 Brake Caliper Upgrade Plug and Play on Mon, 27 Sep 2021 13:23:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vitoast" aria-label="Profile: vitoast">@<bdi>vitoast</bdi></a> The only P&amp;P Brake setup I am aware of is the DTX Front end setup.</p>
<p dir="auto">That is to say, you must swap the entire front end of the DTX over.</p>
<p dir="auto"><img src="https://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20DT125X%2005%20%201.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">In a similar vein, I'm running an RS 125 front end setup.</p>
<p dir="auto"><img src="https://i.imgur.com/cmurYYm.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">Using WR400F forks.</p>
<p dir="auto"><img src="https://i.imgur.com/AMSDO5d.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">Also using RS 125 rear brake + wheel</p>
<p dir="auto"><img src="https://i.imgur.com/sydA5qF.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">Using Brembo pads WHICH STOP ON A DIME!!!</p>
<p dir="auto"><img src="https://i.imgur.com/9T4T589.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto"><img src="https://i.imgur.com/TtVqeXt.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">The rear carrier was heavily modified!</p>
<p dir="auto"><img src="https://i.imgur.com/cykyKhf.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto"><img src="https://i.imgur.com/GogAmiH.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">In other words, I can't be of much help to you as I completely re-engineered my DT to retrofit brakes from another bike.</p>
<p dir="auto">The DTX Front brake setup can be retrofitted to the DTR with an adapter plate.</p>
<p dir="auto"><img src="https://c6.staticflickr.com/8/7220/27961158925_26ab4db984_c.jpg" alt="alt text" class="img-markdown  img-fluid" /></p>
<p dir="auto">But I can't really comment on that as I've never done it personally.</p>
<p dir="auto">Hopefully that helps?</p>
]]></description><link>https://dt125r.co.uk/post/27155</link><guid isPermaLink="true">https://dt125r.co.uk/post/27155</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 27 Sep 2021 13:23:31 GMT</pubDate></item></channel></rss>
