<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Had a boo boo]]></title><description><![CDATA[<p dir="auto">hi everyone</p>
<p dir="auto">For some reason It was a silly mistake when building my engine I put the clutch push rod ball bearing in the shaft before the push rod, and after I put the push rod in sent it down the shaft then realised I put the ball bearing in the wrong order, now I turned the engine up side down on top of a polystyrene box to try and get them both out of the shaft the push rod came out and fell out into the box but haven't noticed the ball bearing.</p>
<p dir="auto">is it possible either the ball bearing is jammed or its fell out the other side of the shaft into the gear box. which will mean I have to strip a fresh build nearly all the way down</p>
<p dir="auto">any suggestions ?</p>
]]></description><link>https://dt125r.co.uk/topic/2824/had-a-boo-boo</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 10:17:06 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2824.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Feb 2022 23:37:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Had a boo boo on Thu, 24 Mar 2022 23:13:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: SpookDog">@<bdi>SpookDog</bdi></a> I managed to get it out with a glow plug magnet luckily it was just in the shaft didn't have to split the case thank god</p>
]]></description><link>https://dt125r.co.uk/post/27626</link><guid isPermaLink="true">https://dt125r.co.uk/post/27626</guid><dc:creator><![CDATA[MH-Bikes-N-Bits]]></dc:creator><pubDate>Thu, 24 Mar 2022 23:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to Had a boo boo on Tue, 08 Mar 2022 17:52:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mh-bikes-n-bits" aria-label="Profile: MH-Bikes-N-Bits">@<bdi>MH-Bikes-N-Bits</bdi></a></p>
<p dir="auto">It could get loose into the activator shaft and into the gearbox if you’re unlucky (looking at one of my old casings)...<br />
I’d try a coat hanger magnetised with a big speaker to try and pull it out, or air like Calum said. Let us know how it turns out if possible please bud?...</p>
]]></description><link>https://dt125r.co.uk/post/27558</link><guid isPermaLink="true">https://dt125r.co.uk/post/27558</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Tue, 08 Mar 2022 17:52:55 GMT</pubDate></item><item><title><![CDATA[Reply to Had a boo boo on Tue, 01 Mar 2022 07:43:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mh-bikes-n-bits" aria-label="Profile: MH-Bikes-N-Bits">@<bdi>MH-Bikes-N-Bits</bdi></a> Just run some compressed air down the clutch actuation arm. Cover the clutch side with a rag to catch the ball bearing. I would very much doubt that the ball bearing will get stuck.</p>
]]></description><link>https://dt125r.co.uk/post/27539</link><guid isPermaLink="true">https://dt125r.co.uk/post/27539</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Tue, 01 Mar 2022 07:43:25 GMT</pubDate></item></channel></rss>
