<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Aftermarket throttle cable]]></title><description><![CDATA[<p dir="auto">I have been trying to get a friend’s 2002 dt125r running properly and get it to be reliable the throttle cable fitted on the bike wasn’t right the cable going to the oil pump the inner cable was way to long so the outer cable was packed out with washers not the best solution so I ordered a throttle cable for the bike from hilevel fitted it to be faced with the same problem you can’t fit the cable wrong has anyone else had this problem</p>
]]></description><link>https://dt125r.co.uk/topic/2998/aftermarket-throttle-cable</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 13:11:15 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/2998.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Oct 2022 20:52:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Aftermarket throttle cable on Mon, 17 Oct 2022 13:11:01 GMT]]></title><description><![CDATA[<p dir="auto">How much did the new cable cost?...</p>
]]></description><link>https://dt125r.co.uk/post/28893</link><guid isPermaLink="true">https://dt125r.co.uk/post/28893</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Mon, 17 Oct 2022 13:11:01 GMT</pubDate></item><item><title><![CDATA[Reply to Aftermarket throttle cable on Sun, 16 Oct 2022 18:42:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/old-boy-racer" aria-label="Profile: old-boy-racer">@<bdi>old-boy-racer</bdi></a> 3rm263010200 is the part number you need for a 2002.<br />
3et263011200 is the part number for 1988-96 which is what I suspect you have. The oil pumps changed in 96.<br />
Genuine Yamaha parts supplier, even if you only use it to acquire the part number to put into eBay.<br />
<a href="https://www.bike-parts-yam.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.bike-parts-yam.com/</a></p>
]]></description><link>https://dt125r.co.uk/post/28892</link><guid isPermaLink="true">https://dt125r.co.uk/post/28892</guid><dc:creator><![CDATA[markus.w]]></dc:creator><pubDate>Sun, 16 Oct 2022 18:42:05 GMT</pubDate></item><item><title><![CDATA[Reply to Aftermarket throttle cable on Sun, 16 Oct 2022 11:48:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/old-boy-racer" aria-label="Profile: old-boy-racer">@<bdi>old-boy-racer</bdi></a><br />
There are different oil pumps on the later bikes. I think the ‘rotor’ is situated on the side ( not the top) and is much larger. You might have a cable for one of those...</p>
<p dir="auto">PS vendors who no nothing often use the ‘88-04’ on everything...</p>
]]></description><link>https://dt125r.co.uk/post/28890</link><guid isPermaLink="true">https://dt125r.co.uk/post/28890</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Sun, 16 Oct 2022 11:48:01 GMT</pubDate></item><item><title><![CDATA[Reply to Aftermarket throttle cable on Sat, 15 Oct 2022 22:51:42 GMT]]></title><description><![CDATA[<p dir="auto">All routed right and double checked to make sure the cable is for the right year it’s only wrong on the oil pump side it’s like the inner is about 12mm to long <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f914.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--thinking_face" style="height:23px;width:auto;vertical-align:middle" title="🤔" alt="🤔" /></p>
]]></description><link>https://dt125r.co.uk/post/28888</link><guid isPermaLink="true">https://dt125r.co.uk/post/28888</guid><dc:creator><![CDATA[old boy racer]]></dc:creator><pubDate>Sat, 15 Oct 2022 22:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to Aftermarket throttle cable on Sat, 15 Oct 2022 21:37:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/old-boy-racer" aria-label="Profile: old-boy-racer">@<bdi>old-boy-racer</bdi></a><br />
You can route the cable the wrong way through the bars headstock/chassis. You have got the right cable for the right year and model haven’t you ?</p>
]]></description><link>https://dt125r.co.uk/post/28887</link><guid isPermaLink="true">https://dt125r.co.uk/post/28887</guid><dc:creator><![CDATA[Scootjockey]]></dc:creator><pubDate>Sat, 15 Oct 2022 21:37:06 GMT</pubDate></item></channel></rss>
