<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Charging at idle]]></title><description><![CDATA[<p dir="auto">Hello guys, what voltage a DTR 125 usually makes to charge the battery at idle? Enough to feed the battery? 12.5v plus</p>
]]></description><link>https://dt125r.co.uk/topic/3011/charging-at-idle</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 10:51:29 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3011.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Oct 2022 17:50:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Charging at idle on Sun, 23 Oct 2022 10:46:06 GMT]]></title><description><![CDATA[<p dir="auto">The mot guy put an advisory on my bike about the lights at tickover. Reckoned that the stator was buggered. I tried to explain to him but ‘he had one when younger’ and so was right <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f644.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--face_with_rolling_eyes" style="height:23px;width:auto;vertical-align:middle" title="🙄" alt="🙄" /></p>
]]></description><link>https://dt125r.co.uk/post/28934</link><guid isPermaLink="true">https://dt125r.co.uk/post/28934</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Sun, 23 Oct 2022 10:46:06 GMT</pubDate></item><item><title><![CDATA[Reply to Charging at idle on Sat, 22 Oct 2022 21:33:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scootjockey" aria-label="Profile: Scootjockey">@<bdi>Scootjockey</bdi></a> yes, with little RPM the bike charges the battery and even spikes to little over 14 volts rarely, i was just a bit worried about idle</p>
]]></description><link>https://dt125r.co.uk/post/28933</link><guid isPermaLink="true">https://dt125r.co.uk/post/28933</guid><dc:creator><![CDATA[Hybrid_Theory01]]></dc:creator><pubDate>Sat, 22 Oct 2022 21:33:12 GMT</pubDate></item><item><title><![CDATA[Reply to Charging at idle on Sat, 22 Oct 2022 21:15:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hybrid_theory01" aria-label="Profile: Hybrid_Theory01">@<bdi>Hybrid_Theory01</bdi></a><br />
On tick over you with lights on you would be lucky to get more than 12.5v, and 11.5v sounds about right. But in the real world we don’t ride on tick over. Measure the charge voltage @3.5k and you should be looking at 13.8 to 14.5 volts. As a rule of thumb 50w @12vdc is about 4 amps current draw. And the last time I checked DT has a 3amp battery, and I would always knock 25% off the battery so you could be looking at a battery with 2.25 amps. Which is not a lot if you want to play with stuff on the bike.</p>
]]></description><link>https://dt125r.co.uk/post/28932</link><guid isPermaLink="true">https://dt125r.co.uk/post/28932</guid><dc:creator><![CDATA[Scootjockey]]></dc:creator><pubDate>Sat, 22 Oct 2022 21:15:41 GMT</pubDate></item><item><title><![CDATA[Reply to Charging at idle on Sat, 22 Oct 2022 20:07:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: SpookDog">@<bdi>SpookDog</bdi></a> i was getting 11 something volts at idle with lights on and a bad chinese velocimeter, the battery was also new, now im rebulding the bike and i will go over the wiring, i will also upgrade the velocimeter, i was thinking about building my own RPM, speed and temperature detector with a Arduino, 3 sensors and a oled display, problem is that it might be a little to bulky, im still researching about it, if you guys have any experience with arduinos i would love the help!</p>
]]></description><link>https://dt125r.co.uk/post/28931</link><guid isPermaLink="true">https://dt125r.co.uk/post/28931</guid><dc:creator><![CDATA[Hybrid_Theory01]]></dc:creator><pubDate>Sat, 22 Oct 2022 20:07:33 GMT</pubDate></item><item><title><![CDATA[Reply to Charging at idle on Thu, 20 Oct 2022 18:59:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hybrid_theory01" aria-label="Profile: Hybrid_Theory01">@<bdi>Hybrid_Theory01</bdi></a></p>
<p dir="auto">I’m my experience idle voltage can be a bit lower than at say, 2500rpm, but I have an early (1988) stator setup with 3 separate coils, 1 each for lights, ignition and charging. AmpH/wattage is another thing, I think...</p>
<p dir="auto">Why do you ask?...</p>
]]></description><link>https://dt125r.co.uk/post/28917</link><guid isPermaLink="true">https://dt125r.co.uk/post/28917</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Thu, 20 Oct 2022 18:59:13 GMT</pubDate></item><item><title><![CDATA[Reply to Charging at idle on Wed, 19 Oct 2022 18:21:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hybrid_theory01" aria-label="Profile: Hybrid_Theory01">@<bdi>Hybrid_Theory01</bdi></a> minimum 13.8 volts. 14v for a gel battery.</p>
]]></description><link>https://dt125r.co.uk/post/28915</link><guid isPermaLink="true">https://dt125r.co.uk/post/28915</guid><dc:creator><![CDATA[markus.w]]></dc:creator><pubDate>Wed, 19 Oct 2022 18:21:20 GMT</pubDate></item></channel></rss>
