<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1998 TDR 125 4FU  Engine Cutting Out When Warm]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Hope you are all well.</p>
<p dir="auto">I have been having some issues with my TDR. The engine keep cutting out when it warms up.<br />
This problem originally only happened in 6th gear on the power-band.<br />
However its since got worse. I wondered if anyone has any advice, I'm hoping its not the stator.</p>
<p dir="auto">What I have done so far.</p>
<p dir="auto">Cleaned Carb &amp; Both Jets<br />
New Spark Plug<br />
New NGK Cap<br />
New HT Lead<br />
New Coil<br />
New Voltage Regulator<br />
Checked Fuel Flow<br />
Checked Air Flow<br />
No overflow Pipes are Blocked</p>
]]></description><link>https://dt125r.co.uk/topic/3211/1998-tdr-125-4fu-engine-cutting-out-when-warm</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 14:28:00 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3211.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Jan 2024 15:07:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1998 TDR 125 4FU  Engine Cutting Out When Warm on Mon, 08 Jan 2024 00:42:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: SpookDog">@<bdi>SpookDog</bdi></a> I believe I have fixed it now. Swapped out the voltage regulator got it up to temps and it ran fine.</p>
]]></description><link>https://dt125r.co.uk/post/31303</link><guid isPermaLink="true">https://dt125r.co.uk/post/31303</guid><dc:creator><![CDATA[Lukeymash]]></dc:creator><pubDate>Mon, 08 Jan 2024 00:42:41 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 TDR 125 4FU  Engine Cutting Out When Warm on Wed, 03 Jan 2024 15:49:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukeymash" aria-label="Profile: Lukeymash">@<bdi>Lukeymash</bdi></a></p>
<p dir="auto">Does it happen at any rev in particular? Throttle full open might be power jet? Does it start up straight again?<br />
If it doesn’t have you checked the spark at the time?…</p>
<p dir="auto">Sorry, more info is King! 🙂 …</p>
]]></description><link>https://dt125r.co.uk/post/31264</link><guid isPermaLink="true">https://dt125r.co.uk/post/31264</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Wed, 03 Jan 2024 15:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 TDR 125 4FU  Engine Cutting Out When Warm on Wed, 03 Jan 2024 15:28:28 GMT]]></title><description><![CDATA[<p dir="auto">I'm going to give it one more look at on the weekend. Then I'm going to try a new stator</p>
]]></description><link>https://dt125r.co.uk/post/31261</link><guid isPermaLink="true">https://dt125r.co.uk/post/31261</guid><dc:creator><![CDATA[Lukeymash]]></dc:creator><pubDate>Wed, 03 Jan 2024 15:28:28 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 TDR 125 4FU  Engine Cutting Out When Warm on Wed, 03 Jan 2024 15:15:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madgyver" aria-label="Profile: MadGyver">@<bdi>MadGyver</bdi></a> I'm Glad to be in the club. I'll keep you updated!</p>
]]></description><link>https://dt125r.co.uk/post/31260</link><guid isPermaLink="true">https://dt125r.co.uk/post/31260</guid><dc:creator><![CDATA[Lukeymash]]></dc:creator><pubDate>Wed, 03 Jan 2024 15:15:31 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 TDR 125 4FU  Engine Cutting Out When Warm on Tue, 02 Jan 2024 15:55:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukeymash" aria-label="Profile: Lukeymash">@<bdi>Lukeymash</bdi></a> Welcome to the "club" I have a similar problem and cannot find the resolution.<br />
I have 2 threads (project thread and electrical section) for that,you may find any info or suggestion that you haven't thought.</p>
]]></description><link>https://dt125r.co.uk/post/31251</link><guid isPermaLink="true">https://dt125r.co.uk/post/31251</guid><dc:creator><![CDATA[MadGyver]]></dc:creator><pubDate>Tue, 02 Jan 2024 15:55:36 GMT</pubDate></item><item><title><![CDATA[Reply to 1998 TDR 125 4FU  Engine Cutting Out When Warm on Tue, 02 Jan 2024 15:32:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukeymash" aria-label="Profile: Lukeymash">@<bdi>Lukeymash</bdi></a></p>
<p dir="auto">Is the radiator full?…</p>
]]></description><link>https://dt125r.co.uk/post/31250</link><guid isPermaLink="true">https://dt125r.co.uk/post/31250</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Tue, 02 Jan 2024 15:32:57 GMT</pubDate></item></channel></rss>
