<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Front Light Not Working]]></title><description><![CDATA[<p dir="auto">Hi guys, something broke again need help <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f605.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--sweat_smile" style="height:1.4em;width:auto;vertical-align:middle" title="😅" alt="😅" />. I was normally riding and out of nowhere my front light stopped working…..<br />
I tried changing the light bulb but nothing i dont have a voltmeter so i dont know if there is any voltage? What should i check ?</p>
]]></description><link>https://dt125r.co.uk/topic/3246/front-light-not-working</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 02:29:13 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3246.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Mar 2024 09:01:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Front Light Not Working on Sat, 09 Mar 2024 11:04:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vcelicka" aria-label="Profile: Vcelicka">@<bdi>Vcelicka</bdi></a></p>
<p dir="auto">Gonna have to check your wiring behind the headlight <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=f5c486023ba" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:1.4em;width:auto;vertical-align:middle" title="🙂" alt="🙂" /> …</p>
]]></description><link>https://dt125r.co.uk/post/31774</link><guid isPermaLink="true">https://dt125r.co.uk/post/31774</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Sat, 09 Mar 2024 11:04:35 GMT</pubDate></item><item><title><![CDATA[Reply to Front Light Not Working on Sat, 09 Mar 2024 07:29:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hotshot-iii" aria-label="Profile: HOTSHOT-III">@<bdi>HOTSHOT-III</bdi></a><br />
Just did still nothing</p>
]]></description><link>https://dt125r.co.uk/post/31773</link><guid isPermaLink="true">https://dt125r.co.uk/post/31773</guid><dc:creator><![CDATA[Vcelicka]]></dc:creator><pubDate>Sat, 09 Mar 2024 07:29:19 GMT</pubDate></item><item><title><![CDATA[Reply to Front Light Not Working on Sat, 09 Mar 2024 07:26:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: SpookDog">@<bdi>SpookDog</bdi></a><br />
Its just no beam the small side bulb idk what is called is working but the main one doesn . Taillight is working just fine</p>
]]></description><link>https://dt125r.co.uk/post/31772</link><guid isPermaLink="true">https://dt125r.co.uk/post/31772</guid><dc:creator><![CDATA[Vcelicka]]></dc:creator><pubDate>Sat, 09 Mar 2024 07:26:56 GMT</pubDate></item><item><title><![CDATA[Reply to Front Light Not Working on Fri, 08 Mar 2024 15:19:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hotshot-iii" aria-label="Profile: HOTSHOT-III">@<bdi>HOTSHOT-III</bdi></a> WD40 also does a brilliant job at reviving plastic and giving it a bit of shine so you’re doing jobs at once if you use your WD40 soaked cloth to give all your plastics a wipe</p>
]]></description><link>https://dt125r.co.uk/post/31770</link><guid isPermaLink="true">https://dt125r.co.uk/post/31770</guid><dc:creator><![CDATA[Stevie Wonder]]></dc:creator><pubDate>Fri, 08 Mar 2024 15:19:21 GMT</pubDate></item><item><title><![CDATA[Reply to Front Light Not Working on Fri, 08 Mar 2024 12:04:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vcelicka" aria-label="Profile: Vcelicka">@<bdi>Vcelicka</bdi></a></p>
<p dir="auto">No high or low beam?…<br />
Is the taillight working?…</p>
<p dir="auto">Check the black earth wire to/from the bulb…</p>
]]></description><link>https://dt125r.co.uk/post/31767</link><guid isPermaLink="true">https://dt125r.co.uk/post/31767</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Fri, 08 Mar 2024 12:04:21 GMT</pubDate></item><item><title><![CDATA[Reply to Front Light Not Working on Fri, 08 Mar 2024 09:47:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vcelicka" aria-label="Profile: Vcelicka">@<bdi>Vcelicka</bdi></a> Start by giving the handlebar switch a good dose of WD40 as these always get neglected, it's a harsh environment for a switch.</p>
<p dir="auto">Use a full can with the straw on the end and spray loads in so it fizzes and bubbles out of all the holes, then operate the switch about 20 times to clean the contacts and free up all the little springs etc inside. Hold a rag underneath so you don't get any on the front brake. Good idea to do this after every time you wash the bike to make the switches last a lot longer.</p>
]]></description><link>https://dt125r.co.uk/post/31766</link><guid isPermaLink="true">https://dt125r.co.uk/post/31766</guid><dc:creator><![CDATA[HOTSHOT III]]></dc:creator><pubDate>Fri, 08 Mar 2024 09:47:26 GMT</pubDate></item></channel></rss>
