<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tip for fitting rear wheel bearings]]></title><description><![CDATA[<p dir="auto">If like me you don’t have a ‘wheeler dealers’ workshop fitting rear bearings can be a bear 🐻 The outer edge is so thin even a well fitted socket can slip and damage the seal on the bearings. My solution is to use the tightening ring fitted to an angle grinder (with a socket on top)…</p>
<p dir="auto"><img src="https://i.imgur.com/YcBFe98.jpeg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Make sure to sticky out side is up so you don’t damage the inner of the bearing.</p>
<p dir="auto">Then use a socket on top as usual. A little bit of heat helps 😜 …</p>
<p dir="auto"><img src="https://i.imgur.com/4YC73j6.jpeg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/topic/3313/tip-for-fitting-rear-wheel-bearings</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 10:36:21 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3313.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Aug 2024 15:01:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tip for fitting rear wheel bearings on Sun, 25 Aug 2024 13:33:46 GMT]]></title><description><![CDATA[<p dir="auto">I’ve always froze my bearings heated up the hub greased everything up then gave a bit of gentle persuasion, never had any problems the couple of times I’ve done it but that’s a pretty handy trick</p>
]]></description><link>https://dt125r.co.uk/post/32228</link><guid isPermaLink="true">https://dt125r.co.uk/post/32228</guid><dc:creator><![CDATA[Stevie Wonder]]></dc:creator><pubDate>Sun, 25 Aug 2024 13:33:46 GMT</pubDate></item><item><title><![CDATA[Reply to Tip for fitting rear wheel bearings on Fri, 16 Aug 2024 06:39:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madgyver" aria-label="Profile: MadGyver">@<bdi>MadGyver</bdi></a></p>
<p dir="auto">I do this as well, it’s just that the outer race  on these is so thin that the slightest slip buggers up the rubber seal.<br />
I learnt this the hard way 😐</p>
]]></description><link>https://dt125r.co.uk/post/32217</link><guid isPermaLink="true">https://dt125r.co.uk/post/32217</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Fri, 16 Aug 2024 06:39:33 GMT</pubDate></item><item><title><![CDATA[Reply to Tip for fitting rear wheel bearings on Thu, 15 Aug 2024 19:54:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: SpookDog">@<bdi>SpookDog</bdi></a> I always keep old bearings for use at this kind of jobs.</p>
]]></description><link>https://dt125r.co.uk/post/32215</link><guid isPermaLink="true">https://dt125r.co.uk/post/32215</guid><dc:creator><![CDATA[MadGyver]]></dc:creator><pubDate>Thu, 15 Aug 2024 19:54:00 GMT</pubDate></item><item><title><![CDATA[Reply to Tip for fitting rear wheel bearings on Thu, 15 Aug 2024 19:10:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spookdog" aria-label="Profile: SpookDog">@<bdi>SpookDog</bdi></a> Yes pretty cool hack, doesn't matter what you use as long as it keeps the impact away from the inner race and doesn't deform the seal :+1:</p>
]]></description><link>https://dt125r.co.uk/post/32214</link><guid isPermaLink="true">https://dt125r.co.uk/post/32214</guid><dc:creator><![CDATA[HOTSHOT III]]></dc:creator><pubDate>Thu, 15 Aug 2024 19:10:16 GMT</pubDate></item><item><title><![CDATA[Reply to Tip for fitting rear wheel bearings on Thu, 15 Aug 2024 15:44:52 GMT]]></title><description><![CDATA[<p dir="auto">Nice tip! I must admit, I have always had bearings replaced by people with a press.</p>
]]></description><link>https://dt125r.co.uk/post/32210</link><guid isPermaLink="true">https://dt125r.co.uk/post/32210</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Thu, 15 Aug 2024 15:44:52 GMT</pubDate></item></channel></rss>
