<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cagiva Mito&#x2F;Raptor&#x2F;Planet N1 Engine Bearing List]]></title><description><![CDATA[<p dir="auto">Useful bearing part numbers for the N1 Cagiva Mito/Raptor/Planet Bottom End:</p>
<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Name</th>
<th>Dimensions (mm)</th>
<th>Part Number</th>
<th>OEM Part Number</th>
<th>Notes</th>
</tr>
</thead>
<tbody>
<tr>
<td>Left Hand Main</td>
<td>25x62x17</td>
<td><a href="https://simplybearings.co.uk/shop/p165568/KOYO-6305C3-Open-Deep-Groove-Ball-Bearing-25x62x17mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">6305C3</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800098349-14800098349-bearing" target="_blank" rel="noopener noreferrer nofollow ugc">800098349</a></td>
<td>Can obtain C4 for looser clearances. C4 bearings have additional internal radial clearances to allow expansion in high speed / temperature environments.</td>
</tr>
<tr>
<td>Right Hand Main</td>
<td>25x62x17</td>
</tr>
<tr>
<td>Left Hand Balancer Shaft</td>
<td>15x42x13</td>
<td><a href="https://simplybearings.co.uk/shop/p165065/KOYO-6302-Open-Deep-Groove-Ball-Bearing-15x42x13mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">6302</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800053248-14800053248-bearing" target="_blank" rel="noopener noreferrer nofollow ugc">800053248</a></td>
<td></td>
</tr>
<tr>
<td>Right Hand Balancer Shaft</td>
<td>15x42x13</td>
<td></td>
</tr>
<tr>
<td>Left Hand Gearbox Output Shaft</td>
<td>20x52x15</td>
<td><a href="https://simplybearings.co.uk/shop/p165067/KOYO-6304-Open-Deep-Groove-Ball-Bearing-20x52x15mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">6304</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800024947-14800024947-ball-bearing" target="_blank" rel="noopener noreferrer nofollow ugc">800024947</a></td>
<td></td>
</tr>
<tr>
<td>Right Hand Gearbox Output Shaft</td>
<td>20x28x13</td>
<td><a href="https://simplybearings.co.uk/shop/p8375/Major-Brand-RNA4902-Needle-Roller-Bearing-With-Flanges-without-Shaft-Sleeve-20x28x13mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">RNA-4902</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800036440-14800036440-roller-bearing" target="_blank" rel="noopener noreferrer nofollow ugc">800036440</a></td>
<td></td>
</tr>
<tr>
<td>Right Hand Gearbox Input Shaft</td>
<td>17x47x14</td>
<td><a href="https://simplybearings.co.uk/shop/p165066/KOYO-6303-Open-Deep-Groove-Ball-Bearing-17x47x14mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">6303</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800043382-14800043382-ball-bearing" target="_blank" rel="noopener noreferrer nofollow ugc">800043382</a></td>
<td></td>
</tr>
<tr>
<td>Left Hand Gearbox Input Shaft</td>
<td>16x24x13</td>
<td><a href="https://simplybearings.co.uk/shop/p8363/Major-Brand-RNA4901-Needle-Roller-Bearing-With-Flanges-without-Shaft-Sleeve-16x24x13mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">RNA-NA4901</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800037198-14800037198-needle-bearing" target="_blank" rel="noopener noreferrer nofollow ugc">800037198</a></td>
<td></td>
</tr>
<tr>
<td>Left Hand Water Pump Shaft</td>
<td>8x12x8</td>
<td><a href="https://simplybearings.co.uk/shop/p8221/Major-Brand-HK1210-Drawn-Cup-Type-Needle-Roller-Bearing-with-Two-Open-Ends-12x16x10mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">HK0808</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800047678-14800047678-roller-cage" target="_blank" rel="noopener noreferrer nofollow ugc">800047678</a></td>
<td></td>
</tr>
<tr>
<td>Right Hand Water Pump Shaft</td>
<td>12x16x10</td>
<td><a href="https://simplybearings.co.uk/shop/p8221/Major-Brand-HK1210-Drawn-Cup-Type-Needle-Roller-Bearing-with-Two-Open-Ends-12x16x10mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">HK1210AA</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800033718-14800033718-needle-bearing" target="_blank" rel="noopener noreferrer nofollow ugc">800033718</a></td>
<td></td>
</tr>
<tr>
<td>Oil Pump Shaft</td>
<td>8x12x8</td>
<td><a href="https://simplybearings.co.uk/shop/p8202/Major-Brand-HK0808-Drawn-Cup-Type-Needle-Roller-Bearing-with-Two-Open-Ends-8x12x8mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">HK0808 </a></td>
<td></td>
</tr>
<tr>
<td>Output Gear Pump Shaft</td>
<td>13x19x12</td>
<td><a href="https://simplybearings.co.uk/shop/p8227/Major-Brand-HK1312-Drawn-Cup-Type-Needle-Roller-Bearing-with-Two-Open-Ends-13x19x12mm/product_info.html" target="_blank" rel="noopener noreferrer nofollow ugc">HK1312</a></td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800049016-14800049016-roller-cage" target="_blank" rel="noopener noreferrer nofollow ugc">800049016</a></td>
<td></td>
</tr>
<tr>
<td>Selector Drum Shaft</td>
<td>24x30x7.5</td>
<td>HK24X30X7.5-TN</td>
<td><a href="https://www.oemmotorparts.com/en/product/cagiva/800062200-14800062200-roller-cage" target="_blank" rel="noopener noreferrer nofollow ugc">800062200</a></td>
<td>This will need to be salvaged due to replacement parts not being easily accessible. Shares parts with KTM/Husqvarna but very expensive and not load bearing so not worth replacing IMO.</td>
</tr>
</tbody>
</table>
<p dir="auto">To completely overhaul the engines bearings you'll need a total of <strong>13</strong> bearings for the crank cases.</p>
<p dir="auto">I have spent all day on this and I <em>THINK</em> it's correct. I've checked and cross referenced the part numbers and my existing cases and have tried to marry up the numbers to real-world buys. If there is a mistake please let me know and I'll update the table.</p>
<p dir="auto">The links are <strong>not</strong> affiliated, they're just a reference to what's around.</p>
]]></description><link>https://dt125r.co.uk/topic/3357/cagiva-mito-raptor-planet-n1-engine-bearing-list</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 03:39:05 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3357.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Dec 2024 18:02:42 GMT</pubDate><ttl>60</ttl></channel></rss>
