<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Battery life?…]]></title><description><![CDATA[<p dir="auto">On average I need a new battery once a year. If I don’t replace it I start to get the headlight dim when I use the brake lights, or even horn sometimes. I’ve tried 5amp, gel, they all die a bit over a year…</p>
<p dir="auto">I’ve always had a Chinese replacement Rectifier/Regulator that came with the bike. It has its own short cable loom (2~3in) The original block connector that is connected to the loom has a melt mark on the connector block. The new~used R/R is marked bn with a load of numbers after it. The lighting coil was FUBAR when I  got the bike as well. It looked like the block connector rested against the exhaust and earthed out the lighting coil, the previous owner replaced the R/R with the cheap and nasty that’s currently on there. I have the new~used R/R to go on and a new battery coming…</p>
<p dir="auto">So my question remains: how often do you have to replace your battery? This only applies to 1988~96 bikes. As I remember they went from 3 coils (A/C lighting) to being totally DC so the headlight ran from the battery and the ‘R/R’ had no provision for A/C for the ‘old fashioned’ headlight on the early bikes…</p>
]]></description><link>https://dt125r.co.uk/topic/3410/battery-life</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 23:58:59 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3410.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Mar 2025 23:07:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Battery life?… on Mon, 10 Mar 2025 20:46:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a></p>
<p dir="auto">I remember you having a Li-ion bonfire <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title="🙂" alt="🙂" /><br />
but the thing I’m most interested in is the old AC/DC bikes that have three coils on the stator. The ignition coil is horizontal on the top of the stator. The lighting and charging coils are at a V at the bottom of the stator.<br />
I don’t claim to understand it but the lighting &amp; charging coils are both numbered the same in the Haynes manual and seem to be connected, unlike the ignition coil which seems to be more isolated.<br />
It would seem to have something to do with my investigation into why my headlight dims badly (when I have a FUBAR battery) when I use the brake lights, horn or indicators.<br />
I’m hoping that the short life of my battery’s is down to the Reg/Rec being of the oriental OEM variety that’s always been on the bike since I got it. Like the lighting coil being burnt out. It’s the last gremlin on the bike since I got it as a basket case back when the pandemic started. Unfortunately my multi metre chose this time to die, just when I want to check the coils….</p>
<p dir="auto">The later DC only bikes (anything with more than 3coils) don’t apply to me, unfortunately <img src="https://dt125r.co.uk/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61c.png?v=5c504cafcc8" class="not-responsive emoji emoji-android emoji--stuck_out_tongue_winking_eye" style="height:23px;width:auto;vertical-align:middle" title="😜" alt="😜" /> ….</p>
]]></description><link>https://dt125r.co.uk/post/32636</link><guid isPermaLink="true">https://dt125r.co.uk/post/32636</guid><dc:creator><![CDATA[SpookDog]]></dc:creator><pubDate>Mon, 10 Mar 2025 20:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to Battery life?… on Mon, 10 Mar 2025 06:27:49 GMT]]></title><description><![CDATA[<p dir="auto">I had the same battery that came with my bike up until 2019 until I misdiagnosed a problem to the battery. So that was 9 years of service and I don't know how long it was on the bike before then...</p>
<p dir="auto">I'd definitely be looking at getting a genuine regulator, I had a lithium battery go up in smoke when I accidently fitted a Chinese regulator to my RS</p>
]]></description><link>https://dt125r.co.uk/post/32634</link><guid isPermaLink="true">https://dt125r.co.uk/post/32634</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Mon, 10 Mar 2025 06:27:49 GMT</pubDate></item></channel></rss>
