<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bike dies randomly]]></title><description><![CDATA[<p dir="auto">Hello guys have a massive problem with my dtx<br />
It idles good at low rpm runs great but if you give her more rmp she just shuts down. After that she start easy but same thing again and again. I think it’s electric problem and I don’t know where to look</p>
<p dir="auto">Magnet have some scratches on it<br />
<img src="https://share.icloud.com/photos/0d9LmKJaCAUdJjEYkdpj3a3wA" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://dt125r.co.uk/topic/3417/bike-dies-randomly</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 23:21:34 GMT</lastBuildDate><atom:link href="https://dt125r.co.uk/topic/3417.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Apr 2025 14:21:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bike dies randomly on Sat, 19 Apr 2025 17:05:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fishy-fish" aria-label="Profile: fishy-fish">@<bdi>fishy-fish</bdi></a> I'll put money it's that then.</p>
]]></description><link>https://dt125r.co.uk/post/32673</link><guid isPermaLink="true">https://dt125r.co.uk/post/32673</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Sat, 19 Apr 2025 17:05:28 GMT</pubDate></item><item><title><![CDATA[Reply to Bike dies randomly on Sat, 19 Apr 2025 12:59:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calum" aria-label="Profile: Calum">@<bdi>Calum</bdi></a> thanks Brother will look i have chinese coil thanks alot for the help</p>
]]></description><link>https://dt125r.co.uk/post/32672</link><guid isPermaLink="true">https://dt125r.co.uk/post/32672</guid><dc:creator><![CDATA[fishy fish]]></dc:creator><pubDate>Sat, 19 Apr 2025 12:59:30 GMT</pubDate></item><item><title><![CDATA[Reply to Bike dies randomly on Fri, 18 Apr 2025 15:03:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">It will be very unlikely to be the magneto as the bike runs off the battery and the output from the stator is rectified to 12V.</p>
<p dir="auto">Based off of your very basic description, some of the common pinch points are:</p>
<ul>
<li>Faulty battery</li>
<li>Faulty wiring
<ul>
<li>Check ignition barrel leads to loom</li>
<li>Side Stand Switch</li>
<li>Kill Switch</li>
</ul>
</li>
<li>Poor/Aftermarket Ignition Coil
<ul>
<li>I've had this problem myself with a Chinese Ignition Coil which basically resulted in the bike running great from cold, then once it warmed up the ignition would die above anything from 5k onwards</li>
<li>Replace with genuine 3RM Ignition Coil</li>
</ul>
</li>
</ul>
<p dir="auto">I am sure there are lots of reasons, but since you've only given a sentence to go by the above should do for now.</p>
<p dir="auto">Don't forget the <code>Search</code> function as others have experience similar issues and the common faults are well documented on here.</p>
]]></description><link>https://dt125r.co.uk/post/32670</link><guid isPermaLink="true">https://dt125r.co.uk/post/32670</guid><dc:creator><![CDATA[Calum]]></dc:creator><pubDate>Fri, 18 Apr 2025 15:03:08 GMT</pubDate></item></channel></rss>
